I just got my predator 2 days ago and tried to install the tune to my 2006 z06. everything seemed to work fine until i decided to go for a ride. When i put the first gear on and started rolling at about 1800rpm the 1st to 4th sign came up and never went out...as you imagine i could not put any other gear even when i stopped the car!! I shut down the engine and started it again, the 1st to 4th sign was out but when i started rolling the same thing happened. I installed the original tune that i backed up when i first pluged the predator in and everything worked fine. Can you please help me with this problem??
By the way the car has a K&N induction kit and a cat back exhaust system. I use 100octane fuel and i was curious if you can help me out with a more aggressive tune after we solve the problem with the 1st to 4th gear
Thanks in advance guys and keep up the good work!!
Best regards
Manolis
