can it be reprogrammed?
DeltaChip Support
bluestang1724
Post by bluestang1724 »
i have a red delta chip (it says im two horny on it, i dont kno if that makes a difference).. but anyways it is programmed for a 01 mustang gt and i wanted to kno if it could be reprogrammed with a custom tune for a different car? or would i have to get a different chip?
RE: can it be reprogrammed?
Yes, it can be reprogrammed, but you'll need to find a dealer that still flashes those older chips, not many do anymore.
bluestang1724
ok thanks... it was replaced by the CMR chip wasnt it? also i have the toggle switch with the wire for it for the delta chip, can that be used on the CMR chip? also can u put more than one tune on the CMR chip?
Return to “DeltaChip”
