2007 silverado abs and brake light coming on after tuning
could anyone tell me why my abs and brake light comes on when i do some adjusting on the performance tune i have a u7194 on a 2007 silverado new body 6.0
RE: 2007 silverado abs and brake light coming on after tunin
Are you changing tire size?
Re: RE: 2007 silverado abs and brake light coming on after t
the first time i tryed to turn the dod off two diffrent times and the lights came on the second time i did change the tire size it had oem 17 inch and i put the oem 20 inch on i didnt know if i needed to change the tire setting so i did to see what it would do thanks for the info
RE: Re: RE: 2007 silverado abs and brake light coming on aft
If your tire sizes are stock, you do not need to change that setting.
my lights only comes on when i turn the speed limiter off
it does it when i turn the dod off to isnt the dod to turn off the 4 cylinder mode so it wont kick on and off . it drives my crazy with my muffler
camarofool
ris there a fix for this yet or someone with the most recently working revision. Im gettting so annoyed by this im ready to look at another brand of programmers. I have an 07 silverado wi th 5.3 w dod no matter what ive tryed it comes back and haunts me Ive even gone back to a revision that hasnt caused any problems in the past the 8r10 but the last two never worked for me 9r05a and 9r07. Please fix this problem soon im going nuts here.
I hope the programmers are still looking into this. At this point Id sell it back to you.
Chris
Chris
2007 silverado
5.3L
K&N intake
5.3L
K&N intake
CANUCKPREDATOR
Supershits has an issue too. My truck HAD a Flashpaq in it from the dealer when I bought it. Traded it for the Diablo. SuperShits would run for a block and then light, bells and whistles.
If I put the stock tire size in, no lights, just the speedo is off. I GPSed to see how much, so I know.
