Fuel Codes on 2007 5.9 Diesel - ASAP!
5.9D
Post by 5.9D »
Customer with 07 Dodge 5.9L
U7131
Coming up with trouble codes
P0251
P0148
Related to fuel delivery. Is this a known problem? What do we do next?
ropnjessi
Re: Fuel Codes on 2007 5.9 Diesel - ASAP!
Post by ropnjessi »
5.9D wrote:Customer with 07 Dodge 5.9L
U7131
P0251
P0148
Do you have anymore history on the truck modifications? Does it have a after market lift pump and so on.....
03'/305 Dually 4 x 4
Platinum FASS/150,/Level II CP3, 60hp.Inj.
Stage 1 cold air box, BD Intercooler
Smarty SSR,62/65/13ss, CFM+
Goerend Trans. Westach, Fuel/Rail Gauges
2011 Laramie Longhorn All Stock
5.9D
RE: Re: Fuel Codes on 2007 5.9 Diesel - ASAP!
Post by 5.9D »
It has a BD Aux Lift pump, lift pump pressure is at 20 psi at idle.
Other than that just the regular 4" exhaust, AFE Stage 2 intake and the U7131
ropnjessi
Post by ropnjessi »
Have you put the truck back to stock conditions to see if the codes still persist? What kind of shape is the harness in? Are all the injector plugs tight? And of coarse are the filter(s) clean?
5.9D
Post by 5.9D »
ropnjessi wrote:Have you put the truck back to stock conditions to see if the codes still persist? What kind of shape is the harness in? Are all the injector plugs tight? And of coarse are the filter(s) clean?
All of the above checked.
Is anyone else experiencing these codes? Wondering if it is an injection pump problem where it isn't operating 100% and when the U7131 is asking for more fuel the problem comes in. Codes come on when asking the engine for more (i.e. when passing) The codes do not come on without the tuner installed. :?:
5.9D
Post by 5.9D »
Any ideas?
ropnjessi
Post by ropnjessi »
Check the rail pressure at WOT, you could do a search on this site for these codes. Is the programmers firmware current? The mods at this site usually respond in the mornings EST.
P0251 Fuel Inj Pump Fuel valve Feedback Circ
P0148 Fuel Delivery Error
cant say I have ever seen these codes before, but it would appear that the fuel system is not keeping up with the commanded pressure in the tunes.
Which tune are you runinf?
Have you tried one of the lower power tunes to see if the problem persists?
And, most importantly, how does the truck feel?
Is it making the extra power?
5.9D
Post by 5.9D »
Mike,
We are going to try a dual feed line. It seems as though it is a CP3 pump problem, maybe was damaged by the lift pump not putting out enough. Most trucks with the auxilary lift pump put out about 26 -28 psi at idle
viper69
Post by viper69 »
I also had a P0148 code but that was using a Dr. Performance 110hp chip. It appears to trigger when my CP3 pump can't can't keep the required rail pressure asked.
04.5 Dodge 3500, 3" BDS lift, 35" tires, Diablosport, ATS Aurora 3000 turbo, FASS 95/150, 60HP nozzles, AFE stage I w/torque tube, 4" exhaust w/Aero muffler, ATS exhaust manifold, ATS arcflow, ATS rear diff. cover, FS2500, NADP "Race" transmission
dunejunkie
Post by dunejunkie »
i got the fuel delivery code three time all three resulted in bad injectors. does the predator add fuel pressure?
06 mega cab predator/puck stack,afe stage 2,cfm+ plentum,zilla boost fooler,maghytec deep trans pan, a-pillar gauges and 5 inch exhaust
Re: RE: Re: Fuel Codes on 2007 5.9 Diesel - ASAP!
dunejunkie wrote:i got the fuel delivery code three time all three resulted in bad injectors. does the predator add fuel pressure?
Yes, most all performance tunes will add a bit of pressure.
johnnymanson
RE: Re: RE: Re: Fuel Codes on 2007 5.9 Diesel - ASAP!
Post by johnnymanson »
sounds like fuel contamination. check your fuel filter housing for shit in it.
JoelHarrison
Post by JoelHarrison »
I have the same fuel delivery code show up often. on all power levels but never when its returned to stock. I have brand new OEM injectors and still get it. its a predator thing i guess. my truck seems to run fine it just looks junky to have check engine light always on in a 60,000$ truck. Also my truck idles like shit in the winter thanks to the predator. Fix this stuff please.
cris92345
Post by cris92345 »
WELL MY 07 5.9 IS IN THE SHOP RIGHT NOW FOR THE SAME CODE. 4RTH TIME. THEY HAVE REPLACED THE LIFT PUMP. SO ILL KEEP YOU POSTED ON WHAT THERE NEXT FIX IS. AND BY THE WAY MY TRUCK STILL SHOWED THE CODE IN STOCK MODE ONLY WHEN IT HAD A HEAVY LOAD. HOPE I CAN HELP. I WAS TOLD BY A CUMMINS DEALER TO CHECK THE FUEL PRESSURE RELIEF VALVE. SO WE WILL CHECK IT OUT.
