No Cruise Control
No Cruise Control
I have the Predator U7191 and a 2006 Pontiac Grand Prix GXP with the LS4 engine. I've installed the Diablo Tune and it works great (except for a jerking issue when the DOD engages). So, I was told to use the No DOD tune (as stated in the other thread), but whenever I use the No DOD tune, the cruise control will not engage. It says it's on, and then it just goes away immediately. Any chance this will be fixed?
I will have someone look into this.
HarmFamily
I have an '06 Monte SS with the LS4, run the 91 no DoD tune and don't have this issue (I tested it the other night on a highway run after seeing this thread). Not saying you don't have the problem, but that it doesn't seem to be inherent to the U7191 as I don't have the issue and can't recreate it.
Good luck,
HF
Good luck,
HF
+1 to Harm... I have not had this issue either... and this is the first time I've heard of this issue... seems to be an isolated incident...
yay... isolated to my GXP =(
Still, it works fine with the tunes + DOD, but not with the tunes - DOD, so as it may not be the Predator's fault per say, however, I believe it's a compatibility issue with the Predator. Either that, or the GXP just simply will not engage cruise control if DOD is turned off - in which case, I say boo to you Pontiac! Your Chevy counterpart can do it... =(
Our GM guys has been a bit busy (just had a baby) but I'll pester him about this today.
I have not been able to get a car in here to test this to see why it is happening.
