Datalogging w/ dataviewer
krazyhouse
Post by krazyhouse »
So I just started tuning with CMR, and had a question about the dataviewer. Is there any way to veiw data in a graph? I find the playback and record functions leave alot to be desired.. Also, any Injector duty cycle or airfloiw lb./min. for dodge gas??
kmac1
RE: Datalogging w/ dataviewer
Post by kmac1 »
Yes, click Edit, Add Chart Tab or you can also click on the icon to the left of the red X. That will open a new tab in graphical format and from there you can select parameters. You don't have to play the log back all the time either, you can click your way through it. Might be worth reading through the help section and spending some time playing with every button in the software to know exactly what they do. Its taken some time but I like using the software alot now.
Kev
Kevin MacDonald
Calibration
www.jpcracing.com
For DiabloSport Tech Support: [email protected]
krazyhouse
Re: RE: Datalogging w/ dataviewer
kmac1 wrote:Yes, click Edit, Add Chart Tab or you can also click on the icon to the left of the red X. That will open a new tab in graphical format and from there you can select parameters. You don't have to play the log back all the time either, you can click your way through it. Might be worth reading through the help section and spending some time playing with every button in the software to know exactly what they do. Its taken some time but I like using the software alot now.
Kev
Thanks Kev. I just got it going yesterday after seeing a screenshot posted my another member. I just got the software litterally 2 weeks ago so just trying to stay with the learning curve of another new system.. Thanks
