U7194 update, again...
jdhunt0
RE: Re: RE: not working for me
Post by jdhunt0 »
Newest release worked for me.
nodaker
Re: RE: Re: RE: not working for me
Post by nodaker »
CANUCKPREDATOR wrote:Are you using the latest version of DSDownloader to install crom in Predator?
Yes, I'm using DSDL v 2.2.1.4
Apparently, the crom does install in the tool okay despite the bootlogger error, but it still doesn't upload to the truck.
2008 GMC Sierra SLT, Z71 Ext. Cab
U7194 v. 9r10
johan
RE: Re: RE: Re: RE: not working for me
Post by johan »
Yeah it does hang on the "installing bootloader" screen after the update, weird bug we are trying to solve but not a show stopper IMHO, please e-mail me or Mike L the backups when your vehicle is not supported and the turn around for a new update are usually 2 days max, the quicker you get us the files the quicker the unit will be updated.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
johan
Post by johan »
New update with 4 new cals included.
http://www.diablosport.com/downloads/pr ... 9t09d.crom
Diablosport INC
johan
RE: Re: RE: U7194 update, again...
Post by johan »
New one with some vette and truck cals added.
http://www.diablosport.com/downloads/pr ... 9t09e.crom
Diablosport INC
crankin 'em out....
Poetique
Post by Poetique »
Go head and crank out u7194-9tcm09f lol
nodaker
Post by nodaker »
Lastest update worked. Thanks guys!
One question...in the Real Time Data menu, I see there are some new features called Watch & Record and Playback.
With the logging and monitoring now combined, I can only watch the Real Time Data for about 3 minutes and then it says "Log Full". I then have to go back in and and thru the menus to monitor again for another 3 mins. I was okay with the short logging times of the U7194 because I could just use a laptop to log, but I could watch the LTFTs and AFR while driving on short trips to make sure they hadn't changed. This seems like a downgrade... :-(
Also, there are now Log Graphing and Log Playback options in "Diagnostics". Neither one of these appear to work and it shows - "Problem: press the center key for more info." Then a screen says "ECKS fatal error" and then it reboots. Is this proper operation? I hope all this feedback is helpful.
U7194 v. 9r10
allterrrain
Post by allterrrain »
I just installed the lastest revision and everything worked fine. It is a little annoying that we can no longer just watch the diagnostics screen without logging, but not the end of the world. I set my injector slope the same as i did on the old tune and evertyhing looks the same so far. Didn't notice any change in power yet but i only drove for 20 minutes and it is only on the 87 octane tune
08 GMC All Terrain 5.3L all alluminum, 4.10 rearend, Magnaflow catback, AFE intake tube with custom airbox, Street and Performance throttle body spacer, Predator 87 octane tune
johan
Post by johan »
The datalog features within the Predator have limited space allotted, best bet is to use the dataviewer app, once you use it you will never use anything else, it is that good :)
Diablosport INC
nodaker
Post by nodaker »
I'm happy to give up some datalogging space....to make room for TCM support hopefully???!!!
edit: After 100 plus miles, this updated tune (9t09e) feels very much the same or maybe worse as far as throttle response. Going back to 9r05a. That one was good...And I could monitor w/o logging.
U7194 v. 9r10
johan
Post by johan »
New one with a bunch of calids added:
http://www.diablosport.com/downloads/pr ... 9t09f.crom
Diablosport INC
schnitzer
Post by schnitzer »
With crom 9t09e my 08 C6 Z06 is finally working to modify diablo tune!!!
Thanks a lot guys!!!
Schnitzer
Poetique
Post by Poetique »
My Predator has gone completely screwy lately, not sure why...
For example, it won't log 90% of the time... I have to reboot it several times and even then, sometimes it refuses.
It also asks me to run the same procedures (turn on ignition, brake, etc) required to install or modify a tune when I'm only trying to do diagnostics. The only difference is that when I get to the diagnostics screen it'll then ask me to turn on my engine.
Assuming it gets to that point without freezing, there are no parameters available for me to log, nor can I select GM Complete, etc.
I forgot what screen I was looking at when I found it, but I recall it mentioning something about an "ECKS Fatal Error" I think it said... the hell is goin on guys?
I was thinking maybe I just need to revert to stock and re-update the predator because maybe some portion of the software got corrupted somehow, but at the same time I'm not even certain if the tuning portion is functioning, and if it is, I have no way of knowing whether or not it's gonna fry the pcm because of whatever is screwed up...
JohnForeman
Re: RE: Re: RE: U7194 update, again...
Post by JohnForeman »
johan wrote:New one with a bunch of calids added:
when these updates come out, how do I know if I need to install them or not?
2010 Camaro
-John
