U7194 update, again...
Re: RE: Re: RE: U7194 update, again...
JohnForeman wrote:
johan wrote:New one with a bunch of calids added:
http://www.diablosport.com/downloads/pr ... 9t09f.crom
when these updates come out, how do I know if I need to install them or not?
2010 Camaro
-John
If it is working now, no need to update as these are simply additions of new calibrations that were missing.
Poetique
RE: Re: RE: Re: RE: U7194 update, again...
Post by Poetique »
Mikel, any thoughts on the error? What the hell is "ECKS"
Re: RE: Re: RE: Re: RE: U7194 update, again...
Poetique wrote:Mikel, any thoughts on the error? What the hell is "ECKS"
Looking into it this morning.
RE: Re: RE: Re: RE: Re: RE: U7194 update, again...
Anyone who has had this fatal ECKS error please post up what revision you are using when it happens.
nodaker
Post by nodaker »
I'm using rev. 9t09e and as I stated in a previous post, I'm getting the "ECKS fatal error screen" when selecting Log Graphing or Log Playback in the diagnostics menu. Also, it hangs up on the bootloader screen after updating and won't reboot itself.
2008 GMC Sierra SLT, Z71 Ext. Cab
U7194 v. 9r10
Poetique
Post by Poetique »
It's very odd... my predator was working perfectly fine up until about a week ago. I decided to try to do some logging since the weather had cleared up a bit and stabilized to make sure my LTFTs were in check, and it just started acting screwy. Hasn't been plugged up to my computer or anything lately, I just plugged it up and it was screwy.
I'm on 9r08 btw...
Denali_Sierra_2008
Post by Denali_Sierra_2008 »
Just tried downloading newsest revision it corrupted my predator and I called you guys just to hear "follow the instructions". I have! Still all I get is a frozen screen saying installing bootloader! I've tried using different revisions too. While computer us downloading them the predator just says installing bootloader. I try turning it off and on it always has improperly upgraded. This thing is useless now! Please help with any other ideas besides follow instructions makes sure u have the USB connected I'm not stupid!
CANUCKPREDATOR
Post by CANUCKPREDATOR »
Not saying your stupid, but that IS the most common issue. COM port 1-5, nothing higher and baud rate at 115,200.
Denali_Sierra_2008
No it's all connected properly mine is com 6 does that mess with the downloader? It's all the settings that made it download b4. Now it doesn't show on the predator is downloading it just shows it on the computer. while predator just says installing bootloader. If I wasn't connecting it would tell me too.
Denali_Sierra_2008
It auto detected on com 6 b4 do I keep using it or I have to change that? No offense but that's stupid! Not me haha
Denali_Sierra_2008
Ok tried all USB ports on computer I have com6 com7 and com8 I suppose to be at com1-5? How do I fix this? Different computer?
Denali_Sierra_2008
Tried it in com2 still nothing
Poetique
Post by Poetique »
Good grief we don't need constant multi-post status updates... edit one.
nestillo
Post by nestillo »
Hi just got my predator yesterday 2009 avalanche 5.3 no flexfuel
Same problem here vehicle not supported. I download the latest crom. Still no luck I back up the original tune. After that check enline was on, fuel needle was on E, I just filled the tank with 93 oct, and transm didn't want to shift. Did a test drive and after 2 minutes everything went back to normal.
PCM
12630501 MAIN OS
12626755 SYSTEM
12626739 FUEL SYSTEM
12626795 SPEEDOMETER
12626717 ENGINE DIAGNOSTIC
12631163 ENGINE OPERATION
12625892 SLAVE OPERATING SYSTEM
12626693 ENGINE
VIN: 3GNEC22J09G178490
concoursd
Post by concoursd »
you need to email [email protected] the backup the predator recorded.
