How to log data
tkp848
How to log data
Post by tkp848 »
new to this tuning and want to log data with my predator. can any one tell me what I need to do this. And also what tune would be best for my car 2009 RT automatic with Flowmaster cat back and modified stock air intake with K&N filter.
2009 challenger RT B5 BLUE
09SuperBee
RE: How to log data
Post by 09SuperBee »
Go to Diagnostics, then Watch & Record. When you are done you can hook it up to your cpu and watch the log in real time. I take my laptop with me in the car so I can record multiple logs(if you are using just the Predator you can only record one at a time), and I think it's easier that way. But it can be done either way. You want to use the 91 or 93 tune and with a CAI installed you go with the CAI tune. Not sure how you modified your intake, and how it will work with the CAI tune. I always run the 93PerCAI tune, and modified it. Raising shift points, Speed limiter, Rev limiter, added some fuel... Once you get a 180 t-stat, then you can also adjust your fan settings as well to keep your car running a lot cooler than stock. But I would try it both ways and run logs to see which one is working the best. If you don't run logs, you will never know how it's really running. It took me a couple months to get my car totally dialed in, but now I have a 12 sec car and love it!
Options I,II,III-Mods: AiraidCAI w/scoop adapter,180 t-stat,Predator w/ Per93 CAI Tune,BT Catch Can&Bling,KillerGlass,CustomABS Cover,LEDGLOW&Streetglow everywhere,Custom Trunk Liner&Enclosure... I can't stop! It's a sickness!
tkp848
RE: How to log data
Post by tkp848 »
Thanks for the advice. I've got the 180 thermostat installed. Im using stock air intake with muffler removed and box sealed to the intake hole in the fender and k&n filter. will try logging some data and see what I've got.
datadave49
RE: How to log data
Post by datadave49 »
Hey Hey
Let me see if we got it right we go to Diagnostics, then Watch & Record. have your laptop connected?Take a ride down the highway pull over and read whats on the laptop?then save it (name it some like ride 1and so on) Do we got it right or did we miss something if so what
Dave
