6.4l with white smoke
hey i have a 2009 f350 with the predator u7164, last revision was in about june or july. at first all my tunes worked good but as of the last few weeks it stumbles and blows white smoke out. thought engine was wrecked but when tunes are out it slowly goes away. i put tunes back in and it comes back after a day or so. almost like egr is sticking or somethin. this cant be normal, would it be a faulty program any suggestions? thanks
RE: 6.4l with white smoke
highly doubtful...sounds like a possible bad injector...white smoke is tough with diesels as it could be coolant or raw fuel. How many miles on the truck? The tunes might just be putting more stress on parts that are worn out.
Don
2002 WS6
2002 WS6
truck only has 8000 miles
hoefully not a part failure this early
I've seen it and heard of it, i actually just was speaking to the service manager at a ford dealership today about the 6.4L, he told me of plenty of odd issues with them. Are you getting any trouble codes at all? What is your cal id?
Don
2002 WS6
2002 WS6
daddygoose
do you have the L30 update on your 6.4. if you dont keep it that way. if ford updates your truck, you will be dead in the water with the preditor untill they come up with a new update for the preditor. i have had my preditor for 2 months and cant do anything with it. when i bought my truck 2 months ago i had the latest and greatest program installed and been waiting patiently ever since.
MooseMauler
Sounds like a similar problem I just had. White/blue smoke on start up and when I hammer on the pedal. Turned out to be the EGR Cooler, Oil Cooler and Head Gaskets were done. 50+ labour involved in that job. Ugly.
'06 F350 CC King Ranch
2.5" Levelling Kit, AFE Free Flow Filter, AFE 4" Turbo Back Exhaust, Pro Comp ATW 34s, 12K lbs Warn Winch, PIAA Offroad Driving Lights
"I have not failed. I've just found 10,000 ways that don't work" ae
thanks for the info guys. found out the problem. dont understand it, but i have an nadp dpf delete module. when its plugged in with chip it makes the truck act up, so ofter i cycle the key i just unplug the module and it runs normal. might be a total coincidense but i tested it a few times.
i remember reading something about those modules and key cycling. White smoke sounds like its in regen mode. I have seen it before on a truck without a dpf and our extreme tune, when it went into regen there was white smoke everywhere...at idle it will fill up the entire street with smoke. Key cycling on those modules might reset the anit bounce counters, which have to do with regen.
Don
2002 WS6
2002 WS6
