So has anyone gotten the Prolific cable to work on vista?
None of the divers work. Even the vista ones. I have 32 bit. What can I do?
RE: So has anyone gotten the Prolific cable to work on vista
nevermind guys i found some other drivers that work. all good
Then tell me which ones work, since I'm having to use my OLD XP laptop.
Ted
Ted
- fireman2118
'05 Magnum R/T - 400 rwhp - 385 rwtq
PPP stage 3 heads, Howards cams 219/227 .600/.575 112 +4 , Ported 6.1 intake manifold, 85mm TB, JBA headers & mids, Corsa Sport, Dominator 3000 stall TC, stage II valve body, Getrag 3.91 LSD, BCR coilovers, Eibach sways, BWoody links, Wilwood big brake kit
Hey,
I've been helping an other guy with the same problem. download this file http://www.prolific.com.tw/support/file ... _10311.zip And your should be ready to go.
Make sure that the cable is set to a com port that isn't higer than 1,2,3 or 4.
Greetings Solid
Greetings Solid
Re: RE: So has anyone gotten the Prolific cable to work on v
THANK YOU!!!!!!!!! I have been trying to get it to work on my vista 64 bit Laptop for weeks"well actually I gave up". This driver worked perfect the first time. Now I don't have to keep going in the house to download files and install them on the tuner. Thanks again.fireman2118 wrote:I had the same problem. Got working drivers here....
http://www.cooldrives.com/wividrforprc.html
