gears
akatoad
gears
Post by akatoad »
I found a place to buy gears for my ram cheap but they dont come with new reluctor ring is there any way to adjust the speedo for gears?
RE: gears
What vehicle?
RE: gears
Ram
RE: gears
Can do for an 04-09 Ram...
akatoad
RE: gears
Post by akatoad »
yes it is an 04 ram. so do i have to get a custom tune or what? cause i don't remember seeing anything about adjusting for gears when i installed the programmer. thanks for the quick reply.
akatoad
RE: gears
Post by akatoad »
also i am running the stock 3.92 gears now. does anyone know how much my gas mileage will change if i go to a 4.56 gear. someone told me i could loose as much as 6 or 7 mpg that seems kind of drastic to me and was just wandering if anyone else had already changed gears and could tell me how much it will change.
KJ2132
RE: gears
Post by KJ2132 »
What tire size are you going to? Or are you not changing
2011 Cadillac CTS-V 4 Door
2008 Chevy 2500 HD Diesel
Quick
RE: gears
Post by Quick »
Hmmm,
let's assume you are in top gear most all the time (otherwise you would be accelerating and it would be about the same).
let's assume gas consumption is about the same through the operating rpm range (to simplify city vs. highway cruising)
So 3.92 to 4.56 would be about a 16% change in rotations. Do you think roughly a 16% drop in gas mileage would be about right?
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
ElectricBlueHemi
RE: gears
Post by ElectricBlueHemi »
You don't need to fix your speedo when changing gears on the ram. The exciter ring on the ring gear is what is used for the speedo and you just use the old one on the new gear set. You only need to change your speedo for tire size change
Re: RE: gears
Quick wrote:Hmmm,
Not how it works. In fact, when I changed the gears on my 96 Trans Am, 3.23 to 4.10, the mileage actually went up. Weirdest shit ever.
Quick
Re: RE: gears
Post by Quick »
Mike_Levy wrote:
Quick wrote:Hmmm,
That would imply that assumption (above) is not valid.
I'm thinking most of the mpg difference is going to come from where you spend most of your time in 5th/top gear. Pretty much, when you're cruising at 35 or above you're going to be in top gear. With the rear end change you're going to be going the same speed but turning a couple of hundred more rpm. So if your engine is a lot more efficient up there that might explain it?
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
snakejr
RE: Re: RE: gears
Post by snakejr »
i have a 03 ram and went from 3.92 to 4.56 gears and actualy got better mpg as well as better off the line torque.
2003 hemi quad cab
aem bruteforce intake
mopar long tube headers
mopar high flow peformance cats
taylor10.2mm shortys
gipson side swept exahust
dmh electronic cut out
stoptech race performance cross drilled/slotted rotors
akatoad
RE: Re: RE: gears
Post by akatoad »
thanks for the info guys. electricblue hemi how does that work, wouldn't the exciter ring turn different speed with different gears and cause your speedo to be off?
