The original thread:
http://www.diablosport.com/index.php?na ... ic&t=18721
So I have a 2001 Durango with a Hemi swap from a 2005 Ram. I have had this swap done for 2 years without probles, but last night I loaded the Diablo up and now I have problems.
When I first started to load the tune, it told me that I need to update the CalID. So last night I updated the CalID, and then went straight to the 93 Oct tune. It was too late to start the truck, so this morning I went out to start the truck and it fired up then imediately died. Tried it again and the same results. I switched to the 91 Oct tune and tried but it wouldn't even fire at all. I switched to the 87 Oct tune, Modified Stock, and the backup all with the same results, no fire. I am pissed at this point because this is my DD.
First off, I did not have any complications during the uploads at all, so the DS did the upload without problem. One thing the I am wondering about is the Sentry Key coding. I had to have B&G flash the PCM when I did the swap because to get rid of Sentry Key, and I am wondering if the Diablo CalID update turned the Sentry Key back on.
Please help on this if anyone has input, as again this is my DD and I have to be at work tomorrow.
Diablo Help. Truck will not start now!!!!!!! Need help ASAP!
RE: Diablo Help. Truck will not start now!!!!!!! Need help A
disconnect your negative battery cable for about 15-20 minutes...
then reconnect it, and try starting the vehicle...
Already done that! Will not do anything for the Sentry Key disabled PCM issue I am having
call diablosport tech support around 9am...
