6.4 Extreme puck stack with Trinity on 6.4 Ford
dozerdogue
I'm having a problem I installed the puck after installing the trinity and just mounted the knob under the steering column. The problem is that on no matter what setting i set the trinity turning the knob to clockwise makes no difference in power. So my question is does the extreme puck have to be plugged into the trinity to work and if so how do you do it? I think I either have a bad harness or a puck. So tonight I removed the puck and need a new one I just received it overnight and was so excited to get it. I was a little baffled. The truck ran alright just no power increase. I checked for diagnostic codes and had none.
RE: 6.4 Extreme puck stack with Trinity on 6.4 Ford
hmmm, verify injection pressure is increasing using the trinity and logging, you should be able to see it increase in real time as your monitoring and turning the knob. This will verify that its doing its job. you feel a definite gain. Use trinity to log a 1/8 mile pass with and without the puck..
Don
2002 WS6
2002 WS6
