09 Ram Hemi,Pinging on 87 tune even with 91 octane
M15
Post by M15 »
Tried 3 different 91 brands. Chevron,Mobile,Shell and still same result. Any help would be appreciated. Dont need engine damage.
2009 Ram R/T
09Laramie
RE: 09 Ram Hemi,Pinging on 87 tune even with 91 octane
Post by 09Laramie »
mine was/is doing the same thing- how much knock are you seeing?
Oosik
Post by Oosik »
I'm having the same problem, I'm using 89 Octane. I was seeing some bad knock, so I switched back to stock. It happens mostly when MDS kicks in and when I get close to WOT. I was seeing all kinds of numbers, I believe my LT Knock was staying around 5 and ST Knock was bouncing a lot. I'm half tempted to get a custom tune unless there is an easy fix.
M15
Post by M15 »
Yeah I've been talking to alot of other people that are having the same problem. I'm back to stock as well no pinging and its pulling harder at wot. Go figure lol! Its just not worth the risk untill we can get a better tune.
2009 Ram R/T
09Laramie
Post by 09Laramie »
what I meant is that mine was knocking a bunch, and that I've added fuel, and the knock has gone down significantly. Certainly into a safe range, and the truck pulls harder with the tune than without. I haven't gotten it quite down to 0 knock yet, but it is definitely close. Personally, I think that tweaking the tune to get the most out of it is part of the fun.
Oosik
Post by Oosik »
About how much fuel did you add and how bad was the knock?
M15
Post by M15 »
Good question. I think I might give that a try. Who knows maybe the conditions were different like elevation, temp ect.. when the tune was made for our trucks. Plus i'm sure this wonderfull california gas isnt helping either. So since I'm pinging at 3/4 throttle, I'm going to throw alittle more fuel at it and see if that helps. Wish me luck.
2009 Ram R/T
