I have a 300c 5.7L
Don't Save Original Backup Data!!
Tool Infomation....
Auto Connect is ENABLED.
Legacy Connect is DISABLED.
A tool was found on COM17 at 115200 baud.
XML RPC commands are AVAILABLE.
XML RPC protocol version is 1.60
Tool type = 'Predator'.
Serial number = '218133393'.
Part number = 'u7135'.
CROM version = 'u7135-9r20 10/16/2009 03:02:49 PM boot3'.
Vehicle VIN = '1A8GCE7246Y167104'.
Vehicle Calibration = ''.
Origional backup NOT saved.
Tool is Married FALSE.
Single user tool FALSE.
Using Class2 Protocol FALSE.
Calibration Updates are SUPPORTED.
A Calibration Update is NOT required.
XML RPC WILL be used for FRG transfers.
Tune compression is AUTOMATIC.
Tune compression is set to ENABLED.
Tool registration is NOT supported.
Tool SUPPORTS multiple ECUs.
Config INDICATES multiple ECUs.
Tool reports 1 ECUs.
From Japan
Don't Save Original Data
RE: Don
What revision onthe Predator?
What is the error on the screen when you try to save the backup file?
