Need help interpreting my log(s)
I have a 2008 Charger Super Bee. Did a couple of data logs. I've attached one. I was accelerating hard onto an on ramp. Can anyone tell me what they see...good or bad?
Thanks!!!!
Thanks!!!!
RE: Need help interpreting my log(s)
Anywhere I can go to learn how to interpret it myself?
2008 Super Bee #165 - K&N Typhoon CAI, Flowmaster Super 44's
HELP!
Re: RE: Need help interpreting my log(s)
I downloaded it and it wouldn't open... Did you try to download it from here and open it to see if it works?JQ3 wrote:WHY NO REPLIES??? WHAT GOOD IS THIS FORUM!!! I know this isn't the first time this has been asked because I have seen several replies to questions just like mine. The file has been downloaded 4 times and no comments???
What good is this forum? Well, just like you said. There have been several, dozens, of replies to the exact same question which has been asked dozens of times. Did you bother to read the threads? Does your log look just like those? Did you Google or search to understand what the parameters are that are being logged? Most of them are the very basic tuning parameters. You should gain a good understanding of them. Again, it's all over the forum and wikipedia type explanations to get started with can be found in the first couple of entries on a Google search.
Did you see something really unusual on your log? Is your car doing something unusual? If you don't know, see above. The value of this forum is when you ask a question like "I'm seeing this which I think is a problem. Does anyone have any ideas why it does that?". Your results on "Hey guys, what do you think of my log?" is going to be hit or miss.
sorry, but I'm not in a really good mood today.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
You could become an engineer or you could be patient and nice and let some one who knows how to, help when they have time or you could read and study the other ques., and answs.JQ3 wrote:Anywhere I can go to learn how to interpret it myself?
This forum has been and is MUCH support and a GREAT forum.
gsjoe
One Bad Bird
(she bites)
(she bites)
RE: Re: RE: Need help interpreting my log(s)
JQ3, I agree with Quick. So after we have that understanding.....
for the hell of it (because I am waiting for the coffee pot and was out of town like others all weekend and did not look at any forums), I did download and was able to open it. It's a mess. Your car must run like crap. You have short term knocking issues and even very rare LONG TERM KNOCK.
Now tell us more. Which tune is that, (please tell me you did not modify anything), and where did not get that gas and how many octane numbers did they lie about giving you? Recommendation: Burn your entire tank of gas, go find the best gas you find and fill-up, load the 91 octane canned tune (CAI or not depending on your air cleaner). Then re-log that thing. While you are at it change that thermostat (search the forum for what to buy), because I can see your water temp is 206 degrees.
If you still look at that log after that and the ST Knock numbers climb together with your pedal pressure, you may have something loose on that engine, it is registering a ST of 7.0 and a LT of 3.5....that thing gets the record!
2006 300C-SRT
Mopar CAI/Toyo 245/275 Stagger
185 T-Stat/Catch Can
DiabloToona CMR Gas tune
Extra "Flex" E-85 tune
I am actually having the same issues as you are,with my 06 5.7 charger.I get unacceptable amounts of ST and LT retard even on my stock tune.I am awaiting a catch can to see if it makes a difference.If i see a difference,i will report back on this thread(dont know if you have one or not).My biggest concern is that the gas here in new york just plain sucks.
Re: RE: Re: RE: Need help interpreting my log(s)
Thanks for the response, I really appreciate it!!! The tune is 93 CAI tune, I've made no changes to the canned tune. I did get my gas from a different BP station though, but since it's my first log I have no idea if the other place was better or not.DGatzby1 wrote:JQ3, I agree with Quick. So after we have that understanding.....
Actually, my car runs "like a raped ape"! But, since I've not been in another SRT-8 that doesn't have knock issues I don't have anything to compare it to.
Thanks again for your HELPFUL response!!!
RE: Re: RE: Re: RE: Need help interpreting my log(s)
Your welcome JQ, but you should go load the 91 Oct tune. Your missing nearly 10 degrees of timing advance at WOT. If you think that car is running good now, your going to be real happy soon!
Load the other tune and re-log after some other gas, you need to see ZERO LT Knock for starters. Check and make sure you don't have anything loose causing false knock noises to be picked up by your sensors. Your sensors are picking up lots of noise. That log was among the worst looking for knock. Then if that is the best gas you can buy, you will have to get more gas programmed in, especially at the low and mid RPM ranges.
2006 300C-SRT
Well, I loaded the 91 Oct tune and filled the tank with 93 Oct. Shell. The results were better but, I'm still getting some LT knock and ST knock. I logged 4 runs. Here's what I could conclude: Results are the maxium results;
Run A:
ST - 5.0 @ 4537 rpms
LT - 1.0 @ 3547
Run B
ST - 6.5 @ 5522 rpms
LT - 1.5 @ 6125
Run C
ST - 7.5 @ 2065 rpms
LT - 3.5 @ 5647
Run D
ST- 3.0 @ 4429rpms
LT - 3.5 @ 4793
Now that I've done that I am sloooowly coming to the conclusion that maybe I should have left this tuner to those who have the tiime and know-how about what to do with data such as the above. I am not comfortable modifying the tune simply because I have no CLUE as to what I'm doing and neither the time to play "part-time tuner"!!! My life doesn't revolve around this car or no car for that matter. I guess I'll load the factory tune and log it to see if there's any ST/LT knock.
Any suggestions would be appreciated. Thanks!!!
Run A:
LT - 1.0 @ 3547
Run B
LT - 1.5 @ 6125
Run C
LT - 3.5 @ 5647
Run D
ST- 3.0 @ 4429rpms
LT - 3.5 @ 4793
Three months and no help.
Well I ended up reloading my stock tune. I logged it and got 3.0 ST KNK and 0 LT KNK. The canned tunes, 91octCAI and 93octCAI, gave me too much knock. I didn't and still don't feel comfortable adding fuel. Hence, I have a Predator which has become a paper weight and a BORING, but safe car. I'm probably overly concerned about blowing my motor, but "better off safe than sorry."
I may try an e-tune, but who do I get? AJ is on a "tune hiatus". He seems to be the popular choice. Who's next? I gotta do something with the Predator it cost me over 300 bucks!
Re: RE: Re: RE: Re: RE: Need help interpreting my log(s)
adding fuel is pretty safe- you won't hurt your engine by running too rich, it's letting it run too lean that can cause more immediate damage to your engine.JQ3 wrote:Three months and no help.Well I ended up reloading my stock tune. I logged it and got 3.0 ST KNK and 0 LT KNK. The canned tunes, 91octCAI and 93octCAI, gave me too much knock. I didn't and still don't feel comfortable adding fuel. Hence, I have a Predator which has become a paper weight and a BORING, but safe car. I'm probably overly concerned about blowing my motor, but "better off safe than sorry."
