black smoke
RocknRamm
black smoke
Post by RocknRamm »
I have a 01 HO 2500 4x4 4 in exhaust. between shifts and when I get on the pedal I get black smoke is this normal, I have no signs of boost leak hitting about 25lbs . thanks Roger
madmanwithmouse
RE: black smoke
Post by madmanwithmouse »
yep you will see some, but if you are getting alot with just the puck then you might have it checked out.
2006 Dodge Ram Cummins 3500 Dully, 4x4, Manual trans:
Predator/Puck, Fass 95 Pump, 4" Turbo back Straight pipe, K/N, Quadzilla moniter and boost fooler, Intake baffle delete, Modded airbox
http://www.dieselbombers.com/index.php?referrerid=1849
