right now i'm running the U7131. i want to add the power puck. but wich one the standard or extreme power puck?
can some one please tell me the difference in the 2 units. also what setting dose the U7131 need to be on when running the power puck.
the U 7131 works great in tow when i tow my jeep. when empty i set to extreme. very pleased with the product so far.
thanks
puck question
deezel_dawg
puck question
06 Dodge QCLB 4x4 5.9 Cummins. AFE TT, B&W Turnover, 4 in TBE , MAG-HYTEC TRANS PAN, A pillar EGT/TRANS Temp/Boost...LOCAL 824
Brooksville FL
Brooksville FL
RE: puck question
the regular puck has 2 settings well 3 with one being off. 60 hp and 90hp. the extreme puck has a dial which you can turn. I have not seen or had anything to do with an extreme, but the regular one works good. I have also not tried to stack them, I have a predator and my brother has a puck. He love it, and I am very happy with my predator, I think (and will one of these try it) the puck gives you a bit more kick at lower rpm or take off, this is what I have gathered from reading.
Reg
- duallydave
RE: puck question
the puck is a presure box,it raises the rail pres which seems to make the pedal feel more sensitive and responsive,as stated above the reg puk only has 3 settings and the extreme has a dial which gives u a linear affect.i had a puck and i liked it,its recomended to use the stacker tuned in the pred when using the puk as the pred raises pres too and to much pres can cause injector isues,since u have gauges you would probaly like the puk,could give u a nice kik in the pants
04 l/box.predator quad race x2 cammander.bhaf.6spd stick.
deezel_dawg
RE: puck question
thanks for the info.
Brooksville FL
Brooksville FL
