2007 chevy silverado classic w/5.3
I recently bout part number u7192 off my buddy to use on my truck. according to all the stuff i have read it should work for my application. I have tried to plug it in and it says engine application not avalaible. what am i doing wrong?
thanks,
Gregg
thanks,
Gregg
RE: 2007 chevy silverado classic w/5.3
What is the 8th and 10th digits of your VIN, along with the revision on the Predator?
The revision is displayed on the top line of the main screen of the tool when powered up.
I am guessing you have the 2.01 or 2.02 revision , as 07 support was added in the 2.03 revision.
If so, this tool will need to be sent in for an update.
If you are the original owner of the tool, and can provide a copy of the receipt, there is no charge other than shipping.
If not the original owner, a charge of $99 will apply.
Click on downloads and then select 'rma request form'.
go to your product support/download page and get the user/owner's manual...
http://www.diablosport.com/index.php?mo ... lay&pid=17
then you can go here for further info about adjusting the tune once you have it installed...
http://www.diablosport.com/index.php?na ... opic&t=917
yeah, your tool is a newer version of the other ones listed on there, but you can use this manual:
http://www.diablosport.com/downloads/pr ... _U7193.pdf
and here's some additional info on the adjustable parameters you may encounter...
http://www.diablosport.com/index.php?mo ... lay&pid=98
thanks for the information. I put the performance tune in my truck yesterdaya dn am extremely happy with how it feels.
It appears I can do alot of stuff with the unit but ill just stick to the performace tune and the 87 octane tune when towing. I like that tI can adjust trie size and speedo as well. thanks
Gregg
Gregg
