2005 GMC Sierra screen wont come on
drewitt16
Post by drewitt16 »
I plug the U7193 in turn the ignition on and nothing happens. I waited a minute. Cycled ignition again. I did unplug the fuses as recommended but everything is off. Radio, heat etc. I don't know what to do. Anything?
drewitt16
RE: 2005 GMC Sierra screen wont come on
Post by drewitt16 »
Sorry. *Did not* unplug the fuses
so it's working now?
drewitt16
Post by drewitt16 »
No. Do I have to pull the fuses for it too work? Seems like a pain in the ass and shouldn't need to be done for it to power on.
no, you don't have to...
so it's not turning on or anything?
is there power to your obd port?
try plugging in the predator with the power adapter in the wall (if you bought the power adapter and cable kit)... or, try plugging it into another car's obd port...
cuz it gets its power from the pbd port... so if your obd port is dead, it won't power it up... check your cig. lighter fuse and aux power fuses to see if they're blown... those are the fuses that also power the obd port in your truck...
jonathanalberto007
Post by jonathanalberto007 »
Check the fuse that powers up your cigarette lighter, as that one is the culprit most of the time, but if is fine than a bad OBD2 connection. Good luck!
drewitt16
Post by drewitt16 »
All the fuses are good. I even pulled out radio, radio amp, and info. I didn't get the power adapter and cable kit so I can't check the predator. I don't think its the OBD port. I just had the dealer hook up the diagnostic tool 2 months ago. I'm out of ideas and really pissed of with either the predator or my truck. I'm not sure which one yet. Anything else I can do?
any GM vehicle's obd port will power it up, doesn't matter if it's a supported vehicle for tuning or not... it will still get power from any obd port...
so, plug in the predator to another vehicle's obd port and see if it powers up...
also, there is a turn-screw on the back of the predator... that's the contrast button for screen brightness... try turning that and see if you get anything on the screen while you're plugged into another obd port...
drewitt16
Post by drewitt16 »
It's not the screen. And I don't have another fm vehicle around me. I'm taking it back tomorrow. See what happens tomorrow when I take it back
Return to “Predator GM Gas”
