Question about how I can self tune
Now I am obviously new to the Diablosport line... I have an 03 Cobra and was curious if I can download a program to data log? Again I am new to this I have always been a pushrod engine with a carb so I am WAY out of my league here... Any info is greatly appreciated..
RE: Question about how I can self tune
Anyone???
you can use your predator to save/record data logs... and you can also use it in conjuction with a laptop and the diablo dataviewer program to log with your laptop...
you can get the dataviewer program from your 7142 product support download page here:
http://diablosport.com/index.php?module ... lay&pid=12
Re: RE: Question about how I can self tune
Thank you ! I dont have the manual with my tuner and am looking for ways to tune it..06MonteSS wrote:you can use your predator to save/record data logs... and you can also use it in conjuction with a laptop and the diablo dataviewer program to log with your laptop...
RE: Re: RE: Question about how I can self tune
How can I real time data log where it shows the fuel table and a/f ratio live in real time? Asks me for a CD install but I have no cd's it came with the car?
Also where can I get a power cord for my predator?
Re: RE: Re: RE: Question about how I can self tune
Without a Wide band o2 sensor and a separate data logger all you can adjust is timing with a manual trans.Derekc294 wrote:How can I real time data log where it shows the fuel table and a/f ratio live in real time? Asks me for a CD install but I have no cd's it came with the car?
2003 Mach 1 K&N cai w/screen
Accufab 60mm Twin TB Steeda Tri-ax
Predator custom tune +1 lean 2k-4k, +1 lean 4k-7k
AFR 12.6-12.8 3/8" Roy Spacer IAC plate
Bassani O/R X 2.5 flowtubes to Delta 40's
w/factory tail pipes
I have an AEM wideband and was hoping I could make a few adjustments to switch to 60lb injectors from the stock ones...Shaken wrote:Without a Wide band o2 sensor and a separate data logger all you can adjust is timing with a manual trans.Derekc294 wrote:How can I real time data log where it shows the fuel table and a/f ratio live in real time? Asks me for a CD install but I have no cd's it came with the car?
Almost like writing my own tune or just adjusting my current one..
RE: Re: RE: Re: RE: Question about how I can self tune
you NEED a custom tune for the injector swap...
I am getting a dyno tune just need driveability to get on and off the trailer for the dyno.. Just getting it there I all I am trying to do...
Contact the shop that is doing the dynotune to send you a file for that. That would be your best bet.
http://www.tpctuning.com
How can I us the DS Downloader to log my car for my tuner.. I am having an issue with my tune and he asked me to do this... Any help is greatly appreciated
