06 6.0 don't feel like it use to.
SCGt94
Post by SCGt94 »
SILVERFORD2828 wrote:I sent the graph's from last night driving see what you think.
i dont think i got these?
Don
2002 WS6
fastgascar
Tune made no difference to engine performance
Post by fastgascar »
SCGt94 wrote:Well it definitely shouldn't feel stock boys, if it does there are some bigger issues. Last guy mentioned similar problems, wound up being a ficm issue, replaced it and all was well. Feel free to blast me some oris for me to work with, i can write something more aggressive to see if its a tune issue or a truck issue.
I sent you an ORIS with calibration id
SILVERFORD2828
RE: Tune made no difference to engine performance
Post by SILVERFORD2828 »
Don C, I resent the drive data log to your email again see if anything is outta whack.
SCGt94
Post by SCGt94 »
got it and replied back
Don
2002 WS6
SILVERFORD2828
My fault. I've resent it
fastgascar
RE: 06 6.0 don
Don,
Sent you the logs of 2 passes.
SILVERFORD2828
RE: 06 6.0 don
Had any luck with my old truck?
SCGt94
RE: 06 6.0 don
Post by SCGt94 »
I believe i got back to both of you no?
Don
2002 WS6
fastgascar
Re: RE: 06 6.0 don
SCGt94 wrote:I believe i got back to both of you no?
I sent you the logs post the tune you sent. Still feels like there is no tune. Goes flat @ the top of the gears.
SCGt94
RE: Re: RE: 06 6.0 don
Post by SCGt94 »
I noticed on one truck fuel was not being added though i was commanding it. Brings me back to my ficm point, could be a possible flash that is now limiting fuel via the ficm OR parameters I have never had to mess with. I should have a 6.0 in here soon enough to mess with.
Don
2002 WS6
fastgascar
Not sure if its my truck or the other. I should have the latest flash, it came out of the dealer last week and they said they had to flash everything to the current version.
SILVERFORD2828
My truck is pitiful. I pulled a 25' dual tandem gooseneck with about 15-16k on it yesterday and could only reach about 21psi of boost. I hope you guys can knock Ford's flash in the head.
fastgascar
Re: RE: Re: RE: 06 6.0 don
SILVERFORD2828 wrote:My truck is pitiful. I pulled a 25' dual tandem gooseneck with about 15-16k on it yesterday and could only reach about 21psi of boost. I hope you guys can knock Ford's flash in the head.
What tune was in the truck? If it isn't the stock tune, Have you tried going back to the stock tune? Wonder if that would have been better?
SILVERFORD2828
RE: Re: RE: Re: RE: 06 6.0 don
I was runnin the stock tune when i was pullin the trailer. And i thought it was fairly powerful when i first got it. Goes to show you how a tuner spoiles a fellar.
fastgascar
RE: 06 6.0 don
I think the FICM flash is the issue. If you can get a 03' untouched FICM I would bet all the power from the ECU programming would come back.
