What are you running for egt's in the different settings
chevy77
Post by chevy77 »
I have a 2004 5.9L 4" straight piped a, but no gauges. Would i be safe running the highest tune without gauges? thanks
duallydave
RE: What are you running for egt
Post by duallydave »
i wouldnt run anything over performance without a egt gauge,i have the same 04 with straight pipe and i have tried every setting,the egts are lowest on tow and once u get into the extreme and rkl they really climb fast,crusing with an outside temp of 10c i see 550-650 on level ground with tow but over 750 with rkl,i have got her up to 1200 easily on rkl but i have my quad camnder set to defuel after 1200.i think the pred uses lots of duration which can be hot,without being able to see it i wouldnt go higher than performance,also depends on outside temos too
04 l/box.predator quad race x2 cammander.bhaf.6spd stick.
RRAM
Post by RRAM »
even on the performance I can pin the needle without effort. after installing my guages I was shocked at how I had been treating my truck. I now am much more mindfull. But life without my predator in not on the books.
Reg
kw5.9
Post by kw5.9 »
I wouldnt go past the tow tune without egt...On tow tune I have it 1325*, and everything above tow can hit 1600* pretty easy...like RRAM said i was shocked at how i was treating the truck also and I am alot more mindfull! Ur stock auto or stick wont like anything above tow tune any way.
Ram 2500 2007.5,5.9ctd,6spd,4X4,predator,puck,Amsoil air filter, AME amsoil, straight pipe turbo back,silencer stolen,quadzilla fooler
