Vehicle not in database ?
so i got a predator from a buddy of mine after he had no luck using it on his 2004 6.0 . after being raped on brokerage fees from UPS getting it over the border i plug it in and turn it on .... FAIL says data is corrupt . after getting this resolved i try to load a tune on my 03 .... FAIL it says that the vehicle is not in the database and to contact my dealer for update. is this a ford pcm update or do i have to update my unit? my cal id is VXAM2N5
RE: Vehicle not in database ?
you need to update your unit. at the top of this website, go to support, downloads, and then choose your part number in the drop down list. all of the software and update instruction document are there to download and use.
so V.9r11 is out of date then ?
serial: 2000da2
part: u7165 pcm-6-0
version: v.9r11
hardware: unknown
bus: can
born : 01/13/2010 11374
bus test : NOT DONE
the unit will read and clear DTC's but thats it
http://www.youtube.com/watch?v=0pBKQGIORes
serial: 2000da2
part: u7165 pcm-6-0
version: v.9r11
hardware: unknown
bus: can
bus test : NOT DONE
pretty sure we spoke today...
yeah we did ... i'll get back to you after hearing from ford
any idea as to when i can expect my cal ID to be included into the tunes ? or should i just get a SCT live wire and sell the predator ?
anything here guys ? i realise its an older cal ID but with the 6.0 if it aint broke dont fix it ....
Working on trying to get a template made up for that id, ill keep you posted.
Don
2002 WS6
2002 WS6
o look at that...making tunes now
, ill let you know when i can spin something off for you to try
Don
2002 WS6
2002 WS6
any progress Don ?
yea you got quite an oddball one, some reallllll old stuff, software is way different then the newer 6.0 stuff. I would actually consider updating the pcm cal id if you can as there is not as much to play with as the newer stuff. But regardless, They will spin test croms on wednesday so i should have something for you then. If i can get one sooner i will try but probably not.
Don
2002 WS6
2002 WS6
this what i'm working with here.. a 1985 ram D350 body on the 2003 F250 FX4
as you can see it don't exactly strike love in Ford tech's hearts and 99% of them say they wont touch it... apparently it doesn't matter how many times i tell them the entire wiring harness and drive train is Ford . they still believe its a cluster f@#k.
now when it comes to flashes from them they out right refuse at some dealers and others want a ludicrous amount of money quoting some 4 hours shop time ! the flash should not take much more then an hour
LOL oooooo now it makes sense! That is bad ass! hmmm where are you located?
Don
2002 WS6
2002 WS6
2 hours south of Toronto, Ontario
