2010 ford MUSTANG GT
polifemo
Post by polifemo »
Hi i use on my car the 93 oct tune (original trinity) and i've removed the speed limiter in the performance option...But when i arrive in 5th gear the cars was stopped at 4380 rpm and not do more (about 140mph)
I want know if someone can resolve this problem and help me ..
RE: 2010 ford MUSTANG GT
sounds like the limiter is not removed.
Try installing the tune again and make sure it is turned off, or export a copy of the last tune written and send it to us.
polifemo
reply
Post by polifemo »
HI i have attached the tune ...I have re insert the tune many time and i'm sure that the limitator are drop off becouse when the car go on 140 mph go over and not stopped the car arrived around 145 mph.But i thing that are a limit in the rpm
custom tune 93 oct.frg
this is the last tune
(5.25 KiB) Downloaded 203 times
tuningss
Re: reply
Post by tuningss »
polifemo wrote:HI i have attached the tune ...I have re insert the tune many time and i'm sure that the limitator are drop off becouse when the car go on 140 mph go over and not stopped the car arrived around 145 mph.But i thing that are a limit in the rpm
Speed limiter fixed!!!
custom_tune_93_oct_597.frg
(960.14 KiB) Downloaded 216 times
http://www.tpctuning.com
RE: Re: reply
w00t!!
polifemo
reply
Post by polifemo »
i've removed the speed limiter you can see this on the tune ....the problem are on rpm probably
RE: reply
have you tried his tune???
polifemo
RE: reply
Post by polifemo »
now i try your tune..wait i must go on hightway :-)
tuningss
RE: reply
Post by tuningss »
Let me know.
polifemo
RE: reply
Post by polifemo »
no ...same problem they go same at the 5th gear
charala
RE: reply
Post by charala »
So does this mean that the speed limiter on my 2010 GT is not disabled either by the Trinity???
polifemo
RE: reply
Post by polifemo »
the limiter are disabled by the trinity but the car in 5th gear don't take all rpm, the rpm stopped at 4200-4350rpm.
brownbros
RE: reply
Post by brownbros »
Maybe the car needs more power to go over 140mph????
Re: RE: reply
brownbros wrote:Maybe the car needs more power to go over 140mph????
agreed...
RE: Re: RE: reply
yeah... agreed x2... it's only a 4.6L Ford afterall....
Return to “Trinity Ford Gas”
