2006 mustang
2006 mustang
In the 87 tune does the tranny shift change at all.
- Vas@Diablosport
RE: 2006 mustang
I have a Trinity and it was working the previous day.
I tried to reconnect to the car and it would not light up
It will work on my PC.
ANy thoughts?
ANy thoughts?
RE: 2006 mustang
check the connector where it plugs into thebottom of the Trinity to make sure it is clipped in on both sides.
RE: 2006 mustang
also check that your OBD port is getting power... make sure you don't have any blown cig. lighter/aux. power fuses...
RE: 2006 mustang
Checked the fuses, all were in working order.jsracer wrote:ok
As a plan B I tested the unit on my girl friend's 07 mustang gt
the result is the same ; unit did not power on.
could it be the cable?
if so, is the cable under warranty?
RE: 2006 mustang
yes.
can you post a pic of the cable, or see the other thread about cables and see if you have the same one?
RE: 2006 mustang
I have the same type( I checked the other post).mikel wrote:yes.
RE: 2006 mustang
please PM me an address to send you the correct cable.
RE: 2006 mustang
Jay Spencer
648 sabal lake dr
Apt 212
Longwood,Fl 32779
648 sabal lake dr
Apt 212
Longwood,Fl 32779
RE: 2006 mustang
Mike,
In order for me to schedule my day, are you going to
give me notice when the cable is shipped?
RE: 2006 mustang
It should ship from here today...
RE: 2006 mustang
I just received the new cable.
Just attached the cable then turned on the t-1000
It lit up , I then turned on the motor.
I selected the monitoring app.
I got not readings in the application.
Any thoughts?
Any thoughts?
