Trouble Codes From Recent Dyno Tune Reflash
06hoss
Post by 06hoss »
I just received a custom dyno tune from my local speed shop (Modular Depot) who is a Diablo dealer. I am now getting two codes popping up every time I drive the car.
P0605 and
P1000
The Predator says that the P0605 is normal for performance tuned vehicles and the P1000 says "OBD Systems Readiness Test Not Complete.
I keep clearing the codes, but the check engine light comes back on every time I run the car and the codes are there again. This has happened twice so far.
Is there something my tuner can change in my tune to stop these codes from popping up?
2006 Mustang GT, 4.6L V8
Predator model CL7140, RevisionV.8r24
The car has a C&L street cold air kit on it and the canned tune that came with the tuner ran fine for approximately a year. I recently added long tube headers to the car so I had it dyno tuned with a new customized tune being added to the car and Predator and now the codes keep popping up. Please advise.
Thanks, Dan
hotdog
Post by hotdog »
I don't know if it will solve your issue, but there is a newer revision for the U7140 (8r37).
These codes should clear themselves after a few key cycles.
whitehoodguy
Post by whitehoodguy »
The P0605 is a code for Internal Control Module Read Only Memory Error..what does this mean...it means that the PCM read only memory is corrupt,basically a problem with the files that where installed into your car. there is no fix for this because of the corrupted file, it also may have damaged the PCM, so i guess you will have to live with it...sorry...o yea as for the P1000 dont worry its just not completed the drive cycle..
njctd79
Post by njctd79 »
I have the same two codes popping up now after installing a Diablosport Airraid CAI calibrated 93 octane tune. So far cycling the key has not made them go away. I clear them and they come back. Model #U7140, v.8r28, Calid FBLF152. What will it take to make these go away. I'll change whatever parts or tune/tuner I have to to fix this.
cole
Re: Trouble Codes From Recent Dyno Tune Reflash
Post by cole »
06hoss wrote:I just received a custom dyno tune from my local speed shop (Modular Depot) who is a Diablo dealer. I am now getting two codes popping up every time I drive the car.
P0605 and
P1000
Thanks, Dan
Do you have a copy of the custom tune on your computer? Also have you contacted Modular Depot about this?
Cole Stevens
Return to “Predator Ford Gas”
