Skip Shift issue...HELP!
fasbird
Post by fasbird »
Bought a new Pred U7135. Using it on a 2010 Challenger RT 6spd. with Mopar CAI. Put in the 91 oct. with CAI tune. Everything worked great and the car seems to run strong. However, the darn Skip Shift is still present. I looked through all the menus, and can't see anything SS related. I looked on this site for downloads for the SS, and didn't see anything.
What am I doing wrong? What am I missing? Getting rid iof the SS is one of the main reasons I purchased. Help!!!
RE: Skip Shift issue...HELP!
anything labeled CAGS ??? (Computer Aided Gear Selection)
CAGS = skip shift
fasbird
Post by fasbird »
I did not see that. I did read a sticky above that was the menu map. It looks like I have to go through "modify tune". I hope I don't screw something up?
yeah... modify tune / quick adjust.....
nah, you're fine...
should be disabled in the tunes already?
are you running the latest revision, 9r23?
fasbird
Post by fasbird »
No, it came with the 9r21 and all loaded good. Should I re-install the stock tune and download the 23 version? I have the cable pkg.
Also, I went today to turn on Dyno mode to disable the ESP. It put all the dash warning lights on. Well, I should say it put on the Brake, ABS, BAS and ESP lights. Is this normal? Or will the 23 software cure this also?
fasbird
Post by fasbird »
BTT for the DS guys.
fasbird
Post by fasbird »
ok, let me try this again, and see if I can get a response.
I own a 2010 Challenger RT 6spd. Just bought a Predator. I updated the unit to the current 23 CROM. I put in the 91 oct CAI DS tune. I still have the skip shift happening. Can someone here give a hand to get rid of the SS? Thanks, I would appreciate it.
calid?
please post last tune written too.
fasbird
Post by fasbird »
2010 5.7 6spd.
calid = 68054009AC
Last tune = perfCAI91oct
additional if needed
Serial# - d003c97
Version - v.9r23 (I updated from original 9r21)
Hardware - UNIV-REV2
Bus - CAN SCIA
Born - 3-2-2010 11345
bighemitex
Post by bighemitex »
when he says last tune written i believe he wants the actual file from the tuner, you need dsdownloader to do that
2003 RCSB Hemi Ram - Stock 20s, U7137, AIRAID CAI, 180* Jet T-Stat, Black Magic E-Fan, 3 Inch Cutout, Hooker Aero Chamber Muffler, TMR Mod, NGK 5306 plugs, Taylor 8.2 thundervolt wires, Pacesetter Longtube Headers, Pacesetter ORY, magnaflow cat, Innovate LC-1,
fasbird
Post by fasbird »
bighemitex wrote:when he says last tune written i believe he wants the actual file from the tuner, you need dsdownloader to do that
10-4 -- Thanks!
rdrnr1963
Post by rdrnr1963 »
I also have a 2010 6 Speed running the 9r23 version with a 93 CAI tune. Skip shift is still present. Has there been, or will there be a resolution to this?
rdrnr1963
Post by rdrnr1963 »
rdrnr1963 wrote:I also have a 2010 6 Speed running the 9r23 version with a 93 CAI tune. Skip shift is still present. Has there been, or will there be a resolution to this?
Other than the specifics listed in the previous person's entries that are paticualar to his Predator, I have done the same thing (93 CAI Tune), skip shift is still present on my 2010 6 sp RT. I'd like to get skip shift turned off. Do I need to send a tune file as well, and if so, what exactly do you need? Just the custom tune file? I already have that saved. I am curious though, the file size of the "custom tune" is a lot smaller than the stock tune which was backed up. Any particular reason, or just the "custom tune" just save changes, and not the whole thing? Either way, I REALLY want skip shift gone if at all possible without having to buy the cable.
rdrnr1963
Re: RE: Skip Shift issue...HELP!
Post by rdrnr1963 »
06MonteSS wrote:anything labeled CAGS ??? (Computer Aided Gear Selection)
CAGS = skip shift
I saw no "CAGS" option in my Predator (U7135 w/9r23 CROM and using on a 2010 RT). Where is that option (CAGS) located within the predator selections?
