rev limiter
stacked06
rev limiter
Post by stacked06 »
i have a problem with my oil pump gear blowing up due to the truck reving over 4000. can i get a 100 horse program writin with a rev limit set at 3500. ori is vxcf7m3.
RE: rev limiter
is your tranny slipping like crazy?
SCGt94
RE: rev limiter
Post by SCGt94 »
rev limiter stock will allow the truck to crank up to 4k, in regard to that i do not touch any rev limiters yatta yatta on the 6.0 as there is no need to rev the trucks higher then stock. The stock shift point should be around 3500
Don
2002 WS6
stacked06
RE: rev limiter
Post by stacked06 »
its a standard shift truck. when the tire light up off the back of the truck and the turbo spools i have a 1/2 a second to remember to lift of the throttle. when muddin or messin around in the snow. was just a thought to keep my truck together ive blown 4..... yes 4 oil pump gears up in 100k. now im outta warranty and dont want to spend the money on new gears every 25k cause i rev the 6.0 over 4k by accident. i have found a replacement gear that is 1200 bucks. they say it will hold up to 4200 revs.
SCGt94
RE: rev limiter
Post by SCGt94 »
ahh thats not good, blast me over a last tune written, ill lower it down for ya.
Don
2002 WS6
