Finding the gauges
Brian-RT/JK
Finding the gauges
Hey,
I'm looking to add some gauges but having trouble finding them.
For example: the knock retard gauges.
Is there a flow chart or area where I can find this type of thing?
I have been looking however I am having no luck, I cant seem to find the Miscellaneous or misfire menus at all.
Thank you
Thank you
RE: Finding the gauges
What vehicle?
Brian-RT/JK
Its a 2009 Challenger RT
Thanks You
Thanks You
'09 BB Chally R/T Roto-Fab true CAI, BT Catch can w Braided Lines, MBRP Cat Back (the first one) 15% tint all around, Sills...
08 Jeep Rubicon Rock Krawler 6' Lift, 37' Kevlars K&N CAI Gibson cat backand everything else required with that stuff 02 Tj & 554 fourwinns
How are you trying find these? You have to go into monitoring, then edit gauge layout. The supplied DiabloSport layouts should have them as well I would think.
Brian-RT/JK
Re: RE: Finding the gauges
I have looked on line many places as well as on this site and in all the user manualsgizmodo wrote:How are you trying find these? You have to go into monitoring, then edit gauge layout. The supplied DiabloSport layouts should have them as well I would think.
I have been able to move around in monitoring etc can add a page to the 07 up layout problem is I can seem to find the gauge to add at all.
I do not see any Knock Retard in any of the layouts
a Simple flow chart as to where all the gauges would be great
RE: Re: RE: Finding the gauges
What you have to do is go under logging and then create a new log. Then once in there you can make your own layouts and add the gauges you want and also add Gauge layout pages. So each time you have a page just hit edit and select the type of gauge that you want next it will give you a huge list from Cooling to performance and also to Throttle and in there you selct the PID thatyou want like Retard knock. Once the layout is made you can go to monitor the layout with out actually recording it. I have not seen under the monitoring menu where to add PIDS in there. The only place I seen that is thru the Logging Menu icon. Hope this helps you out bro.
Jose
Jose
Brian-RT/JK
Ahh, Finally I hope it works I will check it out soon. I was only adding a new page attached to one of the supplied layouts.
Seems similar but I'm guessing my version does not have access to all the gauges only a few
Thanks a mil Knuckles and Gizmodo
Brian-RT/JK
Figures, just went to check things out and it seems the trinity discharged my battery.
Brian-RT/JK
Yeah! Gauge problem Solved.
(Still think its odd that when i add a page the Misc and Misfire options dont show up, Oh Well
Now onto how comes it drains the battery, I figured that problem was solved lol
Thanks Again!
Thanks Again!
Re: RE: Re: RE: Finding the gauges
I think you should go in the Trinity and make sure that you have the correct vehicle, so that it can enable you to see all the PIDS that correspond to your car. if you have the correct vehicle and the latest crom file, then I suggest you contact Diablo tech support man. Is your Trinity not turning off when you shut your car down as to why its discharging the battery on your car?Brian-RT/JK wrote:Yeah! Gauge problem Solved.
Thanks Again!
RE: Re: RE: Re: RE: Finding the gauges
Update: Once you make your Gauge layout thru the Logging icon, it will now be available for you thru the Monitoring Icon as well. So for example I called mine Knuckles_DCX and not it shows up in my Monitoring icon as well.
