2006 Z06 w/Headers - 91 tune coding for cat
Jason_NM
Post by Jason_NM »
I have a 2006 Z06 - added long tubes, no cats. Downloaded 91 tune on a U7194 and modified fan temps and COTS to off. downloaded no problem, car starts fine and seems to run well for approx 15 - 20 min. It then codes (eng light) and error codes for left and right cat ineficiency and starts running poorly. Any help? running ver 9r14 07-09 Truck/SUV 06-09 283425
Jason_NM
RE: 2006 Z06 w/Headers - 91 tune coding for cat
Post by Jason_NM »
Jason_NM wrote:I have a 2006 Z06 - added long tubes, no cats. Downloaded 91 tune on a U7194 and modified fan temps and COTS to off. downloaded no problem, car starts fine and seems to run well for approx 15 - 20 min. It then codes (eng light) and error codes for left and right cat ineficiency and starts running poorly. Any help? running ver 9r14 07-09 Truck/SUV 06-09 283425
...additionally - I pulled my stereo fuse before the download as instructed to by the manual. After downloading and car reset the fuse was re-installed. My 6 cd changer nor radio work now. After a drive it appears my heads up display speedometer stays at 0 mph but the tach works. analog gauges work. The stereo does nothing - no indication of power at all....
Jason_NM
Post by Jason_NM »
After researching on this site I decided to return the car to factory tune. pulled fuse on radio (even though its dead) and successfully put the original back. car starts and runs well no check engine lights. Road test - the HUD is working again - but the check engine light comes on after 15-20 min, as expected (no cats) and starts running crappy like before. I'm going to re-enter all the parms on the 91 tune + download.
Jason_NM
Post by Jason_NM »
downloaded again and roadtested...exact same issue as before w/91 tune. Okay - It's time to wait + hear back from support...
Jason_NM
Post by Jason_NM »
...put fuse back for radio - still nothing
Jason_NM
Post by Jason_NM »
adding downloads of 91 tune and orig
custom_tune 91 and fan cot.grg
91 tune w/cots off and fan changes
(3.25 KiB) Downloaded 236 times
Z06 Orig Backup.grg
original
(49 KiB) Downloaded 239 times
Thats always going to happen. You're running no cats, which first off is not legal, and second is screwing with the computer. You need a custom tune done.
Jason_NM
Post by Jason_NM »
Yea I know now...the HUD works w/original tune back in. Radio still dead. I sent an email to 06MonteSSabout the tune + these problems. He seems to handle the Vette issues
Try disconnecting the battery for a minute, Vettes can be a bit more sensitive to these types of issues after a flash.
Jason_NM
Post by Jason_NM »
called tech support + sent email to [email protected] referencing these posts
waiting on response - thanks
Re: RE: 2006 Z06 w/Headers - 91 tune coding for cat
Jason_NM wrote:called tech support + sent email to [email protected] referencing these posts
mikel wrote:Try disconnecting the battery for a minute, Vettes can be a bit more sensitive to these types of issues after a flash.
huh?
Jason_NM
RE: Re: RE: 2006 Z06 w/Headers - 91 tune coding for cat
Post by Jason_NM »
I'll try the reset on the battery - what is the fix for turning off the cats (COTS).
Custom tune to diusable Cats, COT is disabling the cat over temp fueling.
Jason_NM
Post by Jason_NM »
Okay - I sent my files in
whats the next step?
Jason_NM
Post by Jason_NM »
Is this a simple quick change that you can provide? I planned on a custom tune after my cam change...but I had intened on installing the headers (done) + CAI before the cam. I had thought that the 91 tune would suffice (for headers + CAI) until the cam change.
Return to “General Support”
