I need help with my Predator U7146
Hi everybody!!! this is the problem i have.
i just bought a Predator U7146 for my 2002 GT and i installed the tune already but to be honest i dont feel any changes with the power and on the gas, i dont know if i did something wrong or i need to do a custome tune but i dont know how and im afraid that im going to ruin my car.
Is there a tune that have worked for you? please help!!. thank you.
bullitt1668
RE: I need help with my Predator U7146
I just installed mine as well in my Bullitt.... and I'm having the same feelings.
Please some one answer the following:
Can you upload the DiabloTune (for adding hp & torque) and at the same time raise your "speed limiter" and turn off your "traction control"?
2001 Kenny Brown Mustang BULLITT # 1668
Engine:
DiabloSport Predator
Kenny Brown Suspension that also includes an Extreme Chassis Support System also by KB. 1 of 1 Made!!
Engine:
Yes, you can make those changes at the same time.
If it does not feel like you are making good power be sure that you have good quality fuel of the highest octane available in your area.
bullitt1668
is 93 octane high enough? Do you recommend octane busters?
Engine:
Engine:
Re: RE: I need help with my Predator U7146
93 Octane is high enough. Make sure you're using the 93 octane program if available. Mike was also suggesting using a high quality fuel, name brand like exxon, Mobil, Shell ... instead of gas from the local noname cheapee gas station.bullitt1668 wrote:is 93 octane high enough? Do you recommend octane busters?
bullitt1668
RE: Re: RE: I need help with my Predator U7146
thx! do you know if the U-7146 was the option for different octanes?
Engine:
Engine:
00badstang
I am having the same issues. It seemed to run alot better with the factory tune and advance the timing alittle.
00badstang
00badstang
Re: RE: Re: RE: I need help with my Predator U7146
That is the only thing I'ld like to know.bullitt1668 wrote:thx! do you know if the U-7146 was the option for different octanes?
I have a steeda CIA and flowmaster cat back and the tune gave me the bigest notice in power.
no 93 octanebullitt1668 wrote:thx! do you know if the U-7146 was the option for different octanes?
2003 Mach 1 K&N cai w/screen
Accufab 60mm Twin TB Steeda Tri-ax
Predator custom tune +1 lean 2k-4k, +1 lean 4k-7k
AFR 12.6-12.8 3/8" Roy Spacer IAC plate
Bassani O/R X 2.5 flowtubes to Delta 40's
w/factory tail pipes
hardhitter
RE: Re: RE: Re: RE: I need help with my Predator U7146
What does it mean when it says this unit is not licensed for use on this vehicle? How do I fix it? This is on a 99 Mustang GT manual.
Thanks for the 411.Shaken wrote:no 93 octanebullitt1668 wrote:thx! do you know if the U-7146 was the option for different octanes?
