when in the monitoring menu (07_up Hemi), it won't let you back out of it. You have to unplug the trinity...
known issue?
Monitoring glitch?
RE: Monitoring glitch?
Mine has always worked perfectly
Needless Torque Calibrations
www.needlesstorque.com
I bet you were on a big gauge, like rpm, that updates quickly?
They tend to slow things down sometimes....if you click to change age or exit, then wait a few seconds without clicking anything else, it will work...
Does the same thing in the logging menu even with no PIDs selected.... goes up and down in the monitoring/logging menus fine but will not go over to any of the options on the side (like log, back, exit, etc...). left/right buttons work fine on the main menu...
Modern Muscle, Va.
I see you guys are pretty covered up with other stuff but the problem I'm having hasn't been resolved...
Modern Muscle, Va.
what revision is this?
I amtesting U7137/Trinity onthe bench right now, and all the buttons are working in the 07-up_HEMI_TRUCK layout.
Re: RE: Monitoring glitch?
I am having the same issue..... can't figure out how to exit the "monitoring mode" without having to unplug and power cycle the Trinity. 09 Challenger SRT8. Would you guys give us simple instructions on how to exit "monitoring mode" without having to unplug the tool? Thanks to all.dcweber56 wrote:I see you guys are pretty covered up with other stuff but the problem I'm having hasn't been resolved...
"El Magnifico" 2009 Challenger SRT8 AutoStick, Corsa Sport Catback Exhaust, Trinity 91 Modified Tune, 180 T-stat, Moroso Catch Can, DMH Electronic Cut Outs, ProTorque Billet Stator 3200 RPM High Stall Torque Converter, K&N, BFG 295/40/20w Rear Tires
RE: Re: RE: Monitoring glitch?
I have never seen this, and I was monitoring ina HEMI car this weekend....not sure.
It should be as simple as hitting exit.
