help i cant program my buddies o5 with my diablo
i have 05 auto man date is 10-04...my buddies is a 05 man date 02-05...it give me a ca__id code ..and tells me to call diablo for the update...my consern is if i do this will i be able to still put it back in my truck
- duallydave
RE: help i cant program my buddies o5 with my diablo
get him to check his registration,im kinda sure anything built after 05 is labeled an 06 and ur tuner{7130}wont work on it.
ill i check it out here in min i fixing to go pull his silncer ring out for him...thanks dualydave
Make sure you restore the backup to your truck and that the Predator is on the most recent revision to support the newer calid in your buddies truck.
Re: RE: help i cant program my buddies o5 with my diablo
thats what I was wondering. if he had set his back to stockmikel wrote:Make sure you restore the backup to your truck and that the Predator is on the most recent revision to support the newer calid in your buddies truck.
04.5 dodge CTD, afe monster air intake, quad commander, quad X2, rokktech, auto tranny 4x4 quad cab
diesel bombs dropped here!
http://www.dieselbombers.com/register.p ... rrerid=300
RE: Re: RE: help i cant program my buddies o5 with my diablo
yes my diablo went back to stock befor i tried to program my friends..my question still aint answerd tho will updating my u7130 for my buddys dodge...willl i still be able to use it on my truck
o5 cummins auto 14.56 1/4.on (diablo u7130..k&n cold air 5'' turbo back straight) i now have .transgo shift kit.tci billet converter
As long as you restored the backup, you can go from one truck to another.
If you update, restore the backup first, then reapply the tune to the truck.
thanks mikel
