I have a Predator that came with my 1999 F-350, 7.3. Last year when I bought the truck, I programmed it to 60 h.p. and changed it two or three times. This spring, I tried to change it from 60 to the original tune. It would not do it. When you check the options, it shows the last tune was to the original back-up. When you try to install the 60 hp tune, it tries to make a copy for the original back-up and it says it already has a tune in it. When you try to install the original tune, it says yes, no or force. So basically it won't back up the orginal tune to up it to 60 because it says there is a tune already in place, and won't let you do 40, or 85 because it won't back up the orginial tune due to the fact it says there is already a tune. Can someone help????? There is a small sticker on the back that has a bar code and says 131478 and another sticker that says FORD 7.3.
Ken
Won't Tune
RE: Won
Give us a call with the toolpowered up in the truck please...
