Free update required
Cdvision
Post by Cdvision »
My car is a 2006 Mustang Gt with a FRPP/whipple non-intercooled supercharger. When I connected the Predator to my car it says vehicle not in database contact for free update My cal ID is "FBNSBF8" . My Ford tune is for 93 octane and we only have 91 available and I'm getting some pre-ignition. So I need to be able to knock my global timing back 2 degrees using my Predator U7140(it has the latest firmware installed).
Claude
kmac1
Re: Free update required
Post by kmac1 »
Cdvision wrote:My car is a 2006 Mustang Gt with a FRPP/whipple non-intercooled supercharger. When I connected the Predator to my car it says vehicle not in database contact for free update My cal ID is "FBNSBF8" . My Ford tune is for 93 octane and we only have 91 available and I'm getting some pre-ignition. So I need to be able to knock my global timing back 2 degrees using my Predator U7140(it has the latest firmware installed).
Claude
Claude, Unfortunately the Predator cannot support the Whipple tunes at the moment because they change the Calibration ID. We are working on a fix for this however I have no ETA. The only way to use the Predator for tuning at the moment is to return the car to stock and see one of our CMR Dealers for a custom tune.
Sorry if this creates an inconvenience,
Kevin@DiabloSport
Cdvision
Post by Cdvision »
That sucks. I sent my Ford Racing pro-cal tool in for a recalibration to work on 91 octane fuel and the post office lost it. So I was hoping to be able to use my Predator to make the timing change until I had the chance next month to get a dyno tune. Now I'll have to reorder the pro-cal tool from Ford for $240 just to be able to put the stock tune back in so I can get a dyno tune. :(
kmac1
Post by kmac1 »
Cdvision wrote:That sucks. I sent my Ford Racing pro-cal tool in for a recalibration to work on 91 octane fuel and the post office lost it. So I was hoping to be able to use my Predator to make the timing change until I had the chance next month to get a dyno tune. Now I'll have to reorder the pro-cal tool from Ford for $240 just to be able to put the stock tune back in so I can get a dyno tune. :(
You may not want to buy another Pro-Cal tool. If it works like most tuners it should be vin locked and the only one that can return your car to stock will be the original one you had. This is just a guess on my part I am not totally sure but that is how our Predator works. When you get your car custom tuned you can have the dealer flash it back to a stock Mustang cal. Just get your tuner to load a base file to your Predator before you go the the dealer so you have a tune to load back into it. Hope this helps.
Kevin@DiabloSport
Cdvision
Post by Cdvision »
[quote="kmac1]
Kevin@DiabloSport[/quote]
Hey Kevin, I talked to Ford Racing and ordered a replacement pro-cal that is specific for my cars vin and loaded with a 91 octane tune for the Whipple.
Thanks for the input.
kmac1
Post by kmac1 »
Cdvision wrote:[quote="kmac1]
Kevin@DiabloSport
Thanks for the input.[/quote][/quote]
Cool, good to see it worked out for you. Be sure to check back with us before you get it tuned as the Whipple tune may be supported by the Predator by then.
Kevin@DiabloSport
Cdvision
Post by Cdvision »
Well at least my wife is happy. I'm using the Predator on her V6 Pony and she loves it. I took it off her car to try it on mine without telling her. She came to me saying that there was something wrong with her car and it felt sluggish, unresponsive and shifted slowly.
So the Predator 87 octane tune is back on her car again and all is well.
This just means I'll have to buy another one for my car when I get the dyno tune.lol
Great product guys.
Cdvision
Post by Cdvision »
Hi, I was just wondering if you had support for the Whipple tunes yet?
2006 Mustang GT non-intercooled Whipple/FRPP supercharger.
Cdvision
Post by Cdvision »
Any word on Whipple/FRPP support?
christina
Post by christina »
No as of right now there is no Whipple support, although we may work on it for the future.
Christy High
lurker.
Return to “Predator Ford Gas”
