CMR not really registering, or is but still won't run??!!
milehi
RE: New Laptop won
Post by milehi »
It says I need to register so I click okay to register then it says successful then it reboots. I open again it says need to register.
milehi
RE: New Laptop won
Post by milehi »
I have the software on a couple laptops I have one laptop that puts the tunes into the predators because it has a com port built in but then I make the tunes and work on the tunes of another and one of them is new.
RE: New Laptop won
ok... you should be all set now...
you will need to re-register from both machines, and then you'll be good to go...
milehi
RE: New Laptop won
Post by milehi »
Thank you! What was the issue.
RE: New Laptop won
issue was that you're using a new/different computer now than you used to... prior registration was locked to your old machine...
boostedm3
RE: New Laptop won
Post by boostedm3 »
Same thing happening to me, just downloaded the full version and it wants to keep re-registering.
Uninstalled the demo version as well, with no luck.
jah81592
RE: New Laptop won
Post by jah81592 »
I am getting the continuous registering and it won't find the drivers for the chip burner with Win7 business ultimate 64 bit.
ipsmotorsports
RE: New Laptop won
Post by ipsmotorsports »
I'm having the same issue.
RE: New Laptop won
delete the current registry then re-register the software.
