AC NOT WORKING WITH CUSTOM TUNE
Trinity T-1000
Serial: 6JSUS88-1
Part: u7194 u7194
Version: v.1t07ac
Hardware: Trinity
Bus: CAN
Born: 02/18/2010 13067
Bus test: PASSED
Saved Calid: 596734179522
After custom tuning AC will not turn on. When returned to stock tune AC works just fine. Must be a glitch in the software. Attached is the custom tune with the glitch, PLEASE FIX!
Serial: 6JSUS88-1
Part: u7194 u7194
Version: v.1t07ac
Hardware: Trinity
Bus: CAN
Bus test: PASSED
- 596734179522_custom2.grg
- Custom Tune
- (33.25 KiB) Downloaded 160 times
RE: AC NOT WORKING WITH CUSTOM TUNE
Failed to mention 2005 Pontiac GTO M6
This is a specific Trinity issue we are working on.
WoodburyMan
I have the same exact problem on my 2005 GTO M6 with the Trinity device. If I flash a custom tune file, or built in Diablosport tune, A/C will not work. It seems like the compressor will not kick in but funs will still work and I get warm/ambient air. If I flash stock original tune, A/C will then work. Running latest firmware for Trinity and latest DSDownloader. Some odd bug with the E40 and Trinity?
Noticed it when we had a 96F day on Wed. Not fun with no A/C in that weather... A quick fix would be very very much appriciated..
All right Mike give us some good news! When can we expect to see a fix for the glitch in the CMR software?
Re: RE: AC NOT WORKING WITH CUSTOM TUNE
Its not CMR, it is something in Trinity doing it....Stone2500 wrote:All right Mike give us some good news! When can we expect to see a fix for the glitch in the CMR software?
RE: Re: RE: AC NOT WORKING WITH CUSTOM TUNE
Gotcha. Only an assumption since AC worked just fine with Diablotune prior to custom tuning, using CMR software.
- Ill_Born_SS
Mine TOO... I have got around it temporairly by removing TrinityTunes, Installing Predator 91nonDoD then monitoring with the Trinity,(what a waste) car runs good , AC RUNS..... PLEASE FIND AND FIX ASAP!!!
" Just Friggin Wicked"
Now with TCM support...
Still question remains time frame? When you had to build my CALIDS for my GTO when I first bought the device and it wouldn't work. You told me a date the engineers were slated to work on the project. Ten days later just as you had said I received my crom file and was up and running.
- Ill_Born_SS
Anything yet? another weekend is almost here!
- Ill_Born_SS
TCM to the power of 1
No Transmission Control Management
TCM to the power of 2
No Temperature Control Management
TCM to the power of 3
Temper Control Management ( coming soon )
- Ill_Born_SS
OK, it`s lunchtime! Going to install a Trinity tune and have TRINITY Solar Roasted Dogs for lunch. What are you having?
- Ill_Born_SS
"Still question remains time frame?"
It takes about thirty mins. then you reinstall your stock tune and enjoy your AC while you eat!
WoodburyMan
Bump for the new week!
Any ETA? This is kinda big since it seems it's affecting all older U7191 (Now merged into U7194 on Trinity..) vehicles. (A LARGE chunk of vehicles... Even though it's the Trinity..), and the fact that it's summer when A/C's in full use makes it a bit more prudent. Perhaps something with U7191 set got messed up when they were migrated/imported into the U7194 set for Trinity?
- Ill_Born_SS
Bump,Bump... Any headway on this issue guys?
