U7146 for 01 Cobra
TonysOrangeCapri
U7146 for 01 Cobra
I have removed the stock DOHC 4.6 and changed to a Navigator DOHC 5.4. I have also changed injectors from stock to the 03 Cobra 39lb injectors. I need to know if this Predator will accomidate the injector change, and will I need to change to a different MAF, or stay with the stock Cobra MAF meter? The car starts and runs now with the stock cobra tune, but runs rich, and has horrible throttle response. I need some Diablosport help here. Obviously I need a good dynotune, but I am looking for something to get the car around for a while till I can afford a professional dynotune.
01 Cobra DOHC 5.4
39lb hr injectors
Suliivan Intake Manifold
39lb hr injectors
RE: U7146 for 01 Cobra
Tony, can you post a copy of the original backup file from the Predator here so we can try to whip something up for you to get it running?
Id think the stock MAF swill work for now, I'll ask our ford guys to add their .02 when they get a sec...
stock MAF will work. But we need to at least get the injector change fixed.
TonysOrangeCapri
OK so what information do you need from my predator so you can write me a tune or whatever so that we can get the injector change fixed? Im new to this, so bare with me.
01 Cobra DOHC 5.4
39lb hr injectors
39lb hr injectors
Options/troubleshooting/show calid
TonysOrangeCapri
TonysOrangeCapri
Mike or ken, is that the right code that you need? Is there anything else you need?
01 Cobra DOHC 5.4
39lb hr injectors
39lb hr injectors
Yup, thats it.
Give us a little time to work something up for you.
TonysOrangeCapri
TonysOrangeCapri
Sorry Tony, we've been kinda slammed...this tune is scaled for the cobra injectors, should run pretty well.TonysOrangeCapri wrote:??? Anything yet? Should I be looking someplace else for help with this?
- RVAF3C4_39#inj.frg
- (224.14 KiB) Downloaded 306 times
