LTFT different at lower and higher MPH and RPM
fumi
Post by fumi »
Is there a certain speed I need to maintain to set my LTFT?
At 55mph my LTFT's are .78 and -1.56
At 70mph LTFT are -2.56 and -3.12.
Do I stay or readjust.
rmck490
Post by rmck490 »
Speed doesn't matter as long as you are at a steady cruise speed in the 1800 to 2200 RPM range.
Likely the difference you are seeing is at 55 MPH you are less than 1800 RPMs. In my truck, I have to go 61-63 MPH to get over 1800.
Your 70 MPH readings are probably in the correct range so use those results to adjust your LTFT. Looks like a +2 adjustment will get you where you need to be.
2000 Chevy Silverado 1500 Z71 4WD ECSB 5.3L
U7198 ver 9r17
Diablew Tuned
K&N CAI
Corvette Servo
2sscamaro
Re: LTFT different at lower and higher MPH and RPM
Post by 2sscamaro »
fumi wrote:Is there a certain speed I need to maintain to set my LTFT?
Your trims are good. Don't be chasing them. The will always be slightly different from day to day in different temps and different speeds.
