U7194 (2007 lifted silverado) PROBLEMS
I purchased the Diablo tuner u7194 for my truck 4 months ago. Ever since i've bought it, it says it cant read the CALID and will not load onto my truck.... it tells me the vehical is not suported.... idk if you gave me the 07-07 classic body style or not...... but it wont work...and i even went and bought the 40 dollar usb hook up and talked to tech support and had me do all the revisions correctly and everything....nothing is working...can i contact or get diablo to send me the right chip??
RE: U7194 (2007 lifted silverado) PROBLEMS
Is your truck a classic body style or a new body style truck, and if new, what motor does it have?
Its a new body style...... 5.3 vortech
its the 07 new body style with the 5.3 vortech...315 hp..... what should i do.... id really like a new tune or atleast the correct one..
I would guess that the 8th digit of the VIN is an M.
If so, we do not support that motor, and I would suggest returning the tool.
If it is something other than an M, let me know.
the 8th digit is a J..... what do i do?
OK, the J motor is supported.
Make sure the Predator is on the most recent revision (8r07) and the tune should go in no problem.
i was walked through over the phone by tech support and have it on the 8r06 revision..... it will not load.... ive even called and tried to speak someone but they routed me here.... the tool wont take the revisions and i dont think my computer is set up to do it.... ive been spending hours trying to do this.... i talked to a local performance shop (hp performance in jacksonville fl.) and they said the tool isnt made for my vehical either...... can you send me a revised 8r07 with a return label and ill send you mine....
Well, if it is a U7194 (as it sounds like it is based on the 8r06 revision) then it is indeed the correct tool for your truck.
The updates are not too tough...what problems were you having?
Feel free to give me a call here with everything hooked up and I'll walk you through it.
