2007 charger r/t manual shift points and rev limiter
scott57rt
Post by scott57rt »
What are the mode1 and mode2 manual upshift definitions? What is the stock rev limiter setting for 07 r/t?[/list]
SCOTT57RT - 2007 RT Charger 5.7L - Black Crystal Pearl
Procharged with Inertia Cam
RE: 2007 charger r/t manual shift points and rev limiter
They are 2 different ways of disabling the auto upshift setting.
I think the stock limiter is 6K on the 5.7
scott57rt
Post by scott57rt »
How will the manual shift operate under mode1 as compared to mode2? Will it behave differently depending on which mode I select? I'd like to disable it, but I'd like to know the definitions of each mode before I select a mode.
scott57rt
Post by scott57rt »
I read somewhere else that I should just try both modes and see what works. Is that correct?
Yes.
CountWilhelm
Post by CountWilhelm »
What is a rev limiter/how does it work...what is an upshift definition mode...under what condition/need for power should the latter be changed/altered...thanks!!
Count Wilhelm von Wolf
