GM gas Predator hardware upgrade program in place!
TunerTools
RE: Re: RE: just purchased my u7192
nah.... makes a perfectly fine paper weight. I'll put a Superchips tune in the SSR and try that for a while.
Re: RE: Re: RE: just purchased my u7192
Lloyd, Dan will hook you up....dont do something silly like that.TunerTools wrote:nah.... makes a perfectly fine paper weight. I'll put a Superchips tune in the SSR and try that for a while.
TunerTools
I was just bluffingmikel wrote:Lloyd, Dan will hook you up....dont do something silly like that.TunerTools wrote:nah.... makes a perfectly fine paper weight. I'll put a Superchips tune in the SSR and try that for a while.
RE: Re: RE: Re: RE: just purchased my u7192
lol...
Ieatpeople
i have a 2010 silverado with the 4.8l, your site says the vehicle is supported. i had to update the unit to revision 9r16 (u7194), but it still won't tune the truck in any way. i can datalog through the tool and check/clear trouble codes, but it says "calibration not supported" whenever i try to select "performance tune" from the menu.
the 8th number of the vin on my truck is "A"
select to modify the stock tune and let it save a backup copy of the original stock tune from the vehicle...
then export the original backup tune file from the predator to your PC, and post it up here...
the diablo guys will need it in order to add support for your calibration ID...
Ieatpeople
thanks man....
I'll point it out to the guys when they are back at work in the office on Monday...
Ieatpeople
Added here:Ieatpeople wrote:heres my original backup file:
- u7194-9t17b.crom
- (1.17 MiB) Downloaded 425 times
duweller03
if you buy it brand new, it will be the new version of the tool that will allow you to data log, yes...
if you buy it used, and it's an old model tool on a 2.xx revision, you will not be able to data log... you'll have to send it in to diablosport, along with $99, to get it upgraded to the newer version..
