vehicle/ transmission combination (2) "What a joke this is getting to be
9V11 is Junk Also
9V11 is Junk Also
Well the 9V10 would not work and you sent me a 9t11a that would not work , so I also tried the 9V11 and it will not work. You even had me send you my stock tune to work with ! Trying the 9t11a and 9v11 get the following, Seemed like it was going to work, it saved original, the when going to write tume, picked modify and says "Paramiters not available for this
2007 Gmc Duramax Allison 2500HD 4 wd 4 Door
Blocked and Fingered
Predator u7186
S & B Cold Air Intake
Damon
Predator u7186
Damon
RE: 9V11 is Junk Also
It will still install tunes for sure. It simply did not see your parameters there, simple fix on our end.
NO, it will not install tunes on my end, I have tried several times. And why does the new one not see my parameters ? Thought that is why you sent it because it had been fixed to see our parameters ? Guess have 2 wait a couple more weeks and try again ?
Predator u7186
Damon
Predator u7186
Damon
So, please tell me what happens when you try to install the tune, without adjusting any parameters.
Word for word please....
Just emailed you the Original tune Again, as requested
Predator u7186
Damon
Predator u7186
Damon
Thank you.
My bad the tune will install without adjusting parameters, but what good is this, I could not even calibrate tire size, speed limiter , axil ratio or anything, little lone the new features. Why have a tune that can not be adjusted to the needs ?
Predator u7186
Damon
Predator u7186
Damon
Thats not the point, I assure you.
We will resolve this asap.
K, will be checking daily
Predator u7186
Damon
Predator u7186
Damon
Re: RE: 9V11 is Junk Also
Simple but nothing yet ?mikel wrote:It will still install tunes for sure. It simply did not see your parameters there, simple fix on our end.
Predator u7186
Damon
Predator u7186
Damon
bigdawg04 wrote:Simple but nothing yet ?mikel wrote:It will still install tunes for sure. It simply did not see your parameters there, simple fix on our end.
- u7186_dmx_lly_lbz-9t12b.crom
- (1010.07 KiB) Downloaded 246 times
RE: Re: RE: 9V11 is Junk Also
Mike , I appreciate it but this one does have all the new features listed and will write it to the truck, problem is after its done the truck will start and immediatly die. Tried it several times and tried writing it again several times , with the same results, truck starts and dies ? Don't know if it has anything at all to do with it but the tunes used to show 45,65,85 and 120, now with this one they show tow,60,80 and 120
Predator u7186
Damon
Predator u7186
Damon
Hmmm...any chance you can write one of the tgunes to the truck, then export last written and send it to me?
Are you modifying the tune when it fails? Does it still stall if you do not modify the tune?
It will save original, then I go to 80hp and modify the Axle Ratio, tire size and speed limiter, it writes the tunes just fine and finishes. Unplugged, start truck and die tried several times writing the tune , same results. Have tried with both the 60 hp and 80 hp tune. Have not tried installing without modifying honestly that does me no good with a tune. But until this tune I have always had 45,65,85 and 120 , this tune has tow,60,80 and 120.
Predator u7186
Damon
Predator u7186
Damon
OK, we see what happened, will have a fix asap.
