Help can't get downlaoder to find my Predator on Vista
Questions and comments specific to the DiabloSport Downloader application.
05_blgmag_20
Post by 05_blgmag_20 »
I have downloaded a lot of different driver and finally got one to work thanks to the link a post 2 down from this one Now My computer senses the predtor but the software doesn't.
I have tried everything in the FAQ (changes ports, turned off firewalls, ran as admin,)
I also did the Hyper terminal test, Here are my results:
DEBUG ser_set_baud:62 baud -> 7812
Diablosport Predator. Build u7136-9r01 04/07/2008 12:11:51 PM boot4.
I'm looking for some help and I'm about the pull the little hair I have left out.
jimb
RE: Help can
Post by jimb »
Try the following:
1) Make a note of the baud rate and com port Hyperterminal is using. Then close it. (It will prompt. "Do want to disconnect now?". Select Yes)
2) unplug/re-connect the USB-Serial from the USB side of your PC/Laptop. (This causes the driver to unload/reload and enumerate)
2) Start up DSDownloader, and select Options->Auto Connect. Un-select Auto Connect.
3) Select Connection test tab. Your COM port and Baud rate (115200) should be selectable pull downs. Setup as per step 1.
4) Select Test.
If the test succeeds, DSDL will change to the Express Tune Mode tab.
05_blgmag_20
RE: Help can
When I do that i don't have a Test button just Help, COM, Buad then a check box for compressed send
jimb
RE: Help can
Post by jimb »
what version of DSDL are you running?
Also, you need to give admin rights to DSDownloader.
05_blgmag_20
RE: Help can
Sorry i got the Test to display still says no tool detected
running the 2.2.1.9 How do I give ad min rights
05_blgmag_20
RE: Help can
I also right clicked and sleceted run as Ad min and it still didn't work.
jimb
RE: Help can
Post by jimb »
There is additional information in the FAQ.
http://diablosport.com/index.php?name=P ... pic&t=3622
Also, which USB-Serial adaptor and driver are you using?
05_blgmag_20
RE: Help can
Yeah I have tried all those I got it off ebay and using the 3.0.2 prolific driver.
RE: Help can
Vista just blows....
check out the info here:
http://forum.dslogredux.com/index.php?P ... &board=2.0
05_blgmag_20
RE: Help can
I tried all of those and those didn't work ether
Return to “DS Downloader”
