2010 1500 silverado
pepsi
2010 1500 silverado
Post by pepsi »
im looking to buy a diablo predator and would like to get some well needed info on what i should tune. i just want to get rid of the AFM and TM. I know it disables the AFM or DOD. Does it get rid of the TM 100 percent? The truck is all stock and wasnt to sure if the truck needs to be tuned other than what i want to get rid of..feed back would be much appreciated..Thanks in advance.
CANUCKPREDATOR
RE: 2010 1500 silverado
Post by CANUCKPREDATOR »
on the engine side of things yes, TM is removed. on the transmission side no it isn't.
pepsi
Post by pepsi »
so what is the dff between engine and trans? does it make much of a diff?
pepsi
Post by pepsi »
is there there anything els i should tune other than what i want in ur opinion?
CANUCKPREDATOR
Engine wouldn't go 100% throttle for close to 5 seconds when you put the pedal to the floor.
Tranny tells the engine, don't go 100% throttle yet, I want things mushy. I got a corvette shift servo installed and it VERY much smartens up the 1-2 shifts.
Talk to 06montess on the board about his custom tunes, or any one else that has one of his tunes. He does more than what the Predator tunes do, they are special :) More throttle response, more HP, more MPG
Return to “Predator GM Gas”
