Denali - Speed limit off is not working
alyafeis
Post by alyafeis »
My Trinity # 6JUK063
Part u7194 v.1r07c
Calid:628983631269
Model 2009
Yukon-Denali 6.2L
PCM: as attached
I have used the Tune which was supplied by the Trninty for my Car
Is doing fine except the Speed limiter is not working
When I have turned it off the maximum Speed I Got is 97MPH
When I have turned it on I got more around 105 MPH
However, I would like to remove the speed limit.
Please advise what to do....
PCM_628983631269.grg
PCM
(66.67 KiB) Downloaded 234 times
alyafeis
RE: Denali - Speed limit off is not working
Post by alyafeis »
I'm still waitting for answers.....
Please help......
can you please post the last tune written file too?
yeah, we need the copy of the "last tune written" tune file in order to do anything for ya...
thanks!
alyafeis
Post by alyafeis »
The last tune written!! there is only one tune file came with Trinity for my car is called "DIABLO Tune"
and it can't be downloaded.
Tell me what to do?
alyafeis
No Reply Yet!!
Post by alyafeis »
I just wonder how long should I wait to get help for my query!!!!!!!
RE: No Reply Yet!!
dude... you installed one of the diablo tunes to your truck, right???
well, THAT is the "last tune written" tune file....
so, you need to use the DSDownloader program, and export a copy of THAT "last tune written" tune file, and also need to export a copy of your "original backup" stock tune file...
there are TWO tune files to export from the tool... "original backup" and "last tune written"...
the file you posted, is the "original backup" stock tune file... so now, you need to do the export process again, and this time, select the LAST TUNE WRITTEN tune file to export... and post THAT one up...
alyafeis
Post by alyafeis »
Finally I could download the original file and the Modify-stock-tune
Please find what is going wrong!!!!!!!!!!!!
I really need it..
Thanks in advance
(66.67 KiB) Downloaded 256 times
PCM_628983631269_Modify_Stock_Tune.grg
(1.25 KiB) Downloaded 251 times
This is fixed in the latest update, here:
trinity_u7194-1t07ec_update.crom
(1.09 MiB) Downloaded 249 times
alyafeis
Post by alyafeis »
As soon as you post the updated crom I tryed it on my Denali....
However, I could not pass the 105MPH
Also I have tryed
trinity_u7194-1r07d_update.crom
The problem is still there.
once again I'm seeking your help on this matter.
on your trinity, under options/show information, does it show version 1t07ec?
alyafeis
Post by alyafeis »
Yes It does.
it shows version 1t07ec
please turn off the speed limiter with this revision, and export last written again and the original.
wait, does the trinity even support this calid?
does it offer you the Diablo tune?
alyafeis
Post by alyafeis »
Yes it does support the calid.
and I'm using the Diablo Tune.
Here you could find the origial PCM and the modified PCM.
Return to “Trinity GM Gas”
