Which update do I use for the U7165?
Dawgman
Post by Dawgman »
Guess I'm getting confused by reading all the posts on the forum in regards to the updates available (old and new). What should I be using?? I see there is a 9r12 now on the download section for my vehicle. I'm currently using 9r11. I don't believe my truck has been "flashed" by the dealer (so they tell me). Does the 9r12 provide better mpg's?? What are the pros and cons of each?
2005 Ford F-250
U7165
Eric
Jpritchard
Post by Jpritchard »
If your Cal ID is not a 9 version have someone send you an older Crom file and go back to the good Stuff.
what is your calid?
Options/troubleshooting/show calid
Dawgman
Post by Dawgman »
VXCF4D3
Are you happy with the performance on 9r11?
Dawgman
Post by Dawgman »
The performance is great, but my mileage has suffered...I drive pretty conservative unless otherwise needed.
I sent you an older crom, restore the stock tune then try it out.
Dawgman
Post by Dawgman »
I have had my Predator for 5 years, and have used every update, but I'll download it and give it a try. Thanks, and I'll give you an update in a few weeks.
