Tune posted
HHB
Tune posted
Post by HHB »
Here is the tune that I read from my stock 02 Excursion 7.3. It should be the 60hp economy tune.
Would appreciate if you could add the option to adjust the speed limiter as discussed in the the previous tread (U7170 - Economy tune and adjusting speed limiter).
tnaa4y2.frd
(256 KiB) Downloaded 189 times
RE: Tune posted
There should be an adjustable speed limiter setting in the tool already.
HHB
RE: Tune posted
Post by HHB »
I have been looking through the menus, but cant find it anywhere. I have U7170 (v.7r19d). Do I need to update?
dsquared
Re: RE: Tune posted
Post by dsquared »
HHB wrote:I have been looking through the menus, but cant find it anywhere. I have U7170 (v.7r19d). Do I need to update?
You will probably need the hardware upgrade, also. Do you know how old the Predator tool is? It may have the smaller memory which crashes when you try to update to the newer revision, which has the adjustable parameters.....
HHB
Post by HHB »
Mike,
would appreciate if you could help me with this one. In the previous thread where I posted the initial request you responded with:
"Lower it?
Not with the Predator, but we could write a custom tune to do it."
and
"No charge for the speed limiter tune, export a copy of your tune and post it here..."
OK, where do you want it lowered to?
HHB
Post by HHB »
56 mhp will work fine. Thanks for helping me out.
The factory setting will not go lower than 80 MPH, I set it to 8- mph in this tune.
tnaa4y2_142_80mph.frd
(256 KiB) Downloaded 206 times
HHB
Post by HHB »
That was quick. Appreciate your help. Thanks
